Question about Hisense LHD3204US 32 in. LCD HDTV
Hello, I live in Sydney and my hisense tv is not working very weLL. When you turn it on it makes this high pitched squeaky noise and then after a few minutes it just shuts off and makes a lower noise. Could you please supply me with a quote? And turn around time? It is a flat screen model
Posted by michaelawebb on
Terry
  • Hisense Master
  • 11,377 Answers
5 Related Answers
Anonymous
SOURCE: HISENSE TL2020
is it in demo mode
Posted on Dec 29, 2007
Anonymous
SOURCE: Hisense TL1700 17 in. LCD - AC Adapter
I found their web site for the U.S. and found a 800 number,we called and they we bought a new coverter box.
Posted on Jun 19, 2008
Anonymous
  • 19 Answers
SOURCE: TV turns on and off immediately after??
well the problem its the main board see your tv has 2 boards the power supply and the main one that its incharged of the picture and all your imputs tll you this have the same pro with my element tv made by hisense call them they sell it to me for149 but one of them told me to go to shopjimmy.com hey better price found it for 98.10 plus shipp 108 and got the info of what was causing it from the tv repair guy but he was charging too much just to fix the old board
Posted on Apr 14, 2010
Anonymous
  • 4090 Answers
SOURCE: Hisense tv turns on and off
STOP!
The unit has a fault on its power board and sustain board.
It turns off because the sensor is preventing some component from bacoming overheated and catching fire or damaging further components. Seel professional repair.
Please rate my help++++Thanks for using FIXYA
Posted on May 13, 2010
SOURCE: TV pictures can't come out
www.rolsen.ru/content/tech/PDH4239EU_service_manual%20V1.0.pdf
www.rolsen.ru/.../PDP32XX%20Service%20Manual%200804301.pdf
use these service and repair manuals, to troubleshooting procedures.
Posted on Jun 01, 2010
Testimonial: "Very helpful"
Tv just started making a very high pitched noise, although picture and sound are fine?
Barb, noise may be from a power supply/ transformer on it's way out.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
HELP what is that high pitched noise when tv is on
Is your LCD making buzzing or high pitch noise
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
No picture and makes a squeaky noise when turned on
A Philips with the high pitched whine or squeaky sound has a short usually on the deflection board (the middle board) which can be anything from a cap to the high voltage transformer.
It indicates the set has a short and is in shutdown.
Does not come on and its making a squeaking noise. what could the problem be
The high pitched sound is the set in shutdown and usually means a short in the high voltage area.
1helpful
Trouble turning on tv. High pitched noise/click.
The mainboard might have some loose components, or cold solder , or may be the filter capacitors are becoming faulty. Yes it is worth repairing, bring it to the repair shop. Cheers.
2answers
TV making high pitch sound
Hi, There are usually 1 or 2 fans inside the TV's. Could be worn bearings, or fan blade interference. Sorry, without my electric ear working, I can only guess.
High Pitch buzz noise when plugged in and it doesn't turn on
The tv has a shorted component and that is why is making the noise,call a qualified technician to find it and dont try to use it anymore.Is not a fuse.
No picture, only sharp, squeaky noise
I'm having the same exact problem with mine! I'm looking for a solution also. I opened up the back of the TV and blew out the dust. Then I checked all connections. I put it back together and plugged it in. Now it doesn't make the high-pitched squeeking sound, but I still don't get a picture. My guess is the picture bulb is burnt out. I'm trying to find one online and am planning to fix it myself - wish me luck!
Hisense LHD3204US 32 in. LCD HDTV Logo
Top Hisense Televison & Video Experts
Jean Sintulaire
Ekse
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
