White Sewing Speedylock 1600 Mechanical Sewing Machine Logo
Posted on Jan 30, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I was sewing a minky fabric with my model 1600 and the bottom threads broke. I re-threaded it as the manual shows several times now, but the issue is that the 4 threads do not "chain" together as they should. Do you have any suggestions for this type of problem?? Thanks for your time! ~Michelle
  • Oldknowitall Jan 31, 2018
    Check if one of the needles on the plate snapped off. That would keep it from chaining, especially if it is on a wide setting. If so, you'll need to take it in for repair.
Mary Dunn
Level 2:
Habit-Forming:
New Friend:
  • White Sewing Expert 190 Answers
  • Posted on Jan 31, 2018
Mary Dunn
White Sewing Expert
Level 2:
Habit-Forming:
New Friend:
Answers
190
Questions
7
Helped
36370
Points
458
I think that you must have some of your fabric and lint in your machine. Take a brush ( I use a new paint brush and clean your machine looper areas really well, oil then Totally rethread, take your thread for each guide and treat it like floss going into all of the grooves so that they are seated properly. This should do it, getting your thread seated is the most common problem with overlockers not chaining.
5 Related Answers
bargainbox
Hassy
  • 1388 Answers
  • Posted on Feb 24, 2008
SOURCE: bobbin threading
You may have put the timing out, however, try this before you despair too much......
Ensure the presser foot is firm enough for the fabric you are using and that it will not just pull through easily by hand with the foot and feeddogs together (as the needle ascends), or things will not proceed, and you will be stitching in the same spot.
Generally a setting of 3 seems to work for general purposes, but if you are using very light or very heavy fabric, a sample is always a good idea before you start in earnest....also match the needle to the work for best results.
Ensure that all is clean and free of lint jams....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
jferin
  • 10 Answers
  • Posted on Jul 31, 2008
SOURCE: white 3-4 thread overlock speedylock model 1600 sewing machine manual needed
Manuals for all types of sewing machines can be downloaded from sewingmanualss.com.
Anonymous
  • Posted on Oct 05, 2009
SOURCE: Pfaff Expression 3.0 works great in the shop, but
pfaff expression 2.0 works the same. I spend lots of hours with the thread tension and it don;t give me a good stitch. the needle threed ends up making large irregular loops .
mark24354
Mark T
  • 776 Answers
  • Posted on Nov 23, 2009
SOURCE: My white speedylock 1600 is being difficult.. The
This machine has differential feed (top tension is different from bottom and fabric feed rate can be different from bottom). turn the dials for tension and feed rates to adjust. Adjust bottom tension to tighten bottom threads and possibly speed up bottom feed rate. Tough to say without more info.
Good luck and please rate me.
From White Sewing web site.
"Are wavy fabrics making you seasick? Do puckers leave a sour taste in your mouth? Then you need differential feed. It eliminates distortion and wavy seams when serging knits, plus it prevents puckers and pulled seams on lightweight fabrics. Turn the dial again for instant gathers.
Testimonial: "I believe that rethreading it again finally worked.. I did have to change the differential feed which helped alot.. Thank you for your guidance!!"
Anonymous
  • 1116 Answers
  • Posted on Apr 01, 2010
SOURCE: My serger will only sew a few inches, then the
Been there, done that. Old serger almost went out the window more than once.
Raise the thread antenna and loopers to their highest positions.
Set the tensions to zero. If your serger has auto-tension, raise the presser foot as this also opens the tensions.
Begin threading from the right as indicated in your manual or on the door of the serger.
If this continues, the serger may need to be serviced as the timing could be the problem.
Ask before leaving the serger as the service cost usually starts around $100.
I finally gave in and bought a Babylock with instant jet-air threading.
1helpful
I have a Singer Stylist Model #7258.Serial #H10229C25810334. When I'm sewing,the top stitch is perfect but the bottom stitch comes out like backward C's. How does that even happen!????
Check your stitch sample. Is it actually the top thread showing under the fabric, or is it really the bobbin thread. Generally, thread problems under the fabric are an upper thread problem. Thread issues above the fabric is a bobbin issue.
Try a brand new needle.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread.
Remove the bobbin, check that it is wound smoothly, and install and thread the bobbin case making sure the bobbin spins the correct direction.
From that point, there may need to be some tension adjustments required.
Understanding Thread Tension Threads
If the problem continues, you may need to have it serviced. Perhaps there is a burr or snag somewhere that is interfering with the thread in the thread path.
How to adjust tension?
Consult the owner's manual. Be sure to always RAISE the presser foot when threading the upper thread.
Test the stitch. If the thread is looping under the fabric, the upper thread tension is too loose. If the bottom thread shows on the top of the fabric, the upper tension is too tight. The tension is correct when the two threads (top & bobbin) meet in the middle of the fabric.
NOTE: when you change needle/thread/fabric, the tension should be tested on a piece of the project's scrap fabric and readjusted before beginning the project. Tension is static and should be adjusted every time a project is changed. (One tension will not work for every project, so get comfortable with tweaking.) Be sure to change needles frequently (damaged needles are an inexpensive fix for a lot of sewing issues). Making sure needle/thread/fabric are compatible is very important. All About Needles
1helpful
2answers
I have a problem with the tension. the top of my fabric looks fine, but the bottom has big loops from the top thread.
Here are some things to try to make your sewing experience more pleasant:
If you don't have an owner's manual. Get one. Search the internet for the Manufacturer + Model + the word "Manual" and hopefully you will find a free download.
First thing: Put in a brand-new needle. Make sure you are installing the flat part of the needle as directed in the owner's manual. Damaged needles are probably the number one cause of a sewing machine issue. For some reason, sewists are very frugal with their needle supply. However, needles should be replaced frequently to achieve the best sewing result and the least problem. Needles are a very inexpensive "fix" for frustrating issues. Also, do NOT sew over pins. It will not only damage the needle and possibly knock the machine out of time but is also dangerous because broken needle pieces can fly a long distance--into your eye or elsewhere.
Try a different type thread. Old and inexpensive brands of thread can cause problems.
(See the Maintenance Section of the manual.) Clean any dust, lint, and thread pieces from the feed dogs and bobbin area. Be sure to oil your machine as recommended in your owner's manual. Use ONLY good quality sewing machine oil (not 3-in-1, grandma's old oil tin, WD-40, or cooking oil), and apply only one to two drops each spot as directed in your manual. Do NOT oil rubber (belts), plastic, cams, or leather.
Clean the tension disks. Remove all the thread from the machine. Loosen the upper thread tension as much as possible, then gently pull a length of UN-waxed dental floss or pearl cotton between the tension disks to clean them and remove any dust, lint, gunk, or pieces of thread. Do this several times to get everything removed that shouldn't belong.
Be sure to RAISE the presser foot BEFORE threading the upper thread (this releases the tension disks so the thread will seat properly).
Re-thread from the beginning verifying that it is threaded properly (consult your manual).
If your thread is globbing up under the fabric, you are probably experiencing thread nesting or birds nesting. Here's a handy web site:
Sewing Machine Thread Bunching Up Here Why
sewing machine birdnesting
Usually birdnesting occurs when the upper tension is too loose or it is not threaded correctly. Try tightening and then test.
If the upper thread is pulling the bobbin thread to the top of the fabric or is breaking while stitching, the tension is too tight. Try loosening and test.
The tension is correct when both, the upper thread and bobbin thread, meet in the middle of the fabric.
As a sewist, you will be using different weights of thread and fabric as well as different sizes and types of needles, so adjusting the upper tension to suit each circumstance should become second nature for you. This web site may be helpful when determining which needles to use for which project: All About Needles
Adjusting bobbin tension should be attempted only if you understand the consequences. Bobbin tension should be done only in small increments and you should be able to comfortably return it to the original setting.
Here's a video showing how to pull the bobbin thread to the top of the machine that will help avoid thread nesting when you begin to sew.
How and Why to Bring up the Bobbin Thread
HANDY TIP: to help threading the needle's eye, instead of licking the end of the thread, lick your finger and then swipe it across the back side of the needle's eye. The moisture in the eye will draw the thread into place.
Needle is picking up several threads from the bobbin after i have been sewing and jams
Remove the bobbin and case from the bottom. Try dusting it out and add a little oil. Also, check both top and bottom thread tensions. If that does not help then you may have a timing issue which requires a lot more technical expertise.
Aug 09, 2014 • Singer 3810
2answers
Bernina 1230 Is there a way to adjust the pressure on the presser foot?
Just checked on U-Tube there are several video's there for problems, otherwise there is a spring at the top of the needle shaft that can be loosened. Good Luck!
Janome sewing machine
the thread that you changed to is a lighter weight thread & the top tension must
be adjusted to work well with the thread & fabric
needles & thread have to work togeather with the fabric,, & the tension needs
to be check every time thread & needles & fabric are changed
Bobbin thread showing on top, automatic tension
It is possible the jam threw off the timing and this will need to be fixed by a sewing machine tech.
Try one more thing first. Lift the presser foot - this will open the tension control so the thread can properly seat into the control.
Re-thread the machine.
If this does not help, back to suggestion # 1.
4helpful
My white speedylock 1600 is being difficult.. The top threads lay and look perfect.. but the bottom threads are loose.. What can I do about this?
3answers
JANOME RX18S
If it was sewing correctly BEFORE the needle break...why did the needle break in the first place?...and what fixes did you make?
If it sewed properly...what changed?
Cut your upper thread close to the spool...make sure the presser foot is raised and pull the cut off thread section through/out of the machine from the needle area (sewing direction...do not pull the thread backwards!)
Clean out the bobbin area...remove any traces of lint or pieces of thread...look for any broken off needle pieces... brush the bobbin area out....then add a drop of sewing machine oil (but only if your manual says to oil that area).
Remove the needle plate to expose the feed dogs...brush/clean out that area too and add a drop of sewing machine oil...then secure the needle plate back on.
Replace the needle...do it again...yup...some needles arrive bad from the factory. Make sure the needle is inserted and positioned properly. Then thread the machine WITH the presser foot in raised position. (The thread needs to get seated into the upper tensions.)
..with the.presser foot down...thread the new needle.
Oh...and use the correct needle for the thread. (a universal 80/12 is standard).
Thread can cause issues too. Try a different bobbin, or maybe a different spool of thread to see if that makes a difference.
Bobbin tangle
can not thread bobbin...bobbin on top
Top White Sewing Sewing Machines Experts
ZJ Limited
ZJ Limited
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
