Question about AEG Washing Machines
Im sorry to say that you will need to cal the AEG engineer for a quote as the display cannot be black, it should display some information on start up anyway eric
Posted on Jan 17, 2018
SOURCE: electrolux ewf 1435 washing machine
i can not find e50 in any of my servive manuals, are you sure it is e50 ?
Posted on Feb 19, 2008
SOURCE: Electrolux EWF 1087 error code E60
user manual tells you what faults are
could be blocked inlet valve not filling in correct time or pump blocked
not draining in correct time
Posted on Mar 15, 2008
SOURCE: whats is the total weight of electrolux ewf 1495?
thas a question that the manufactuer should be able to answer for you, ifnot the dealer that your goingto purchase tehunit through should be able to get you those specs.
Posted on Mar 12, 2009
SOURCE: AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Posted on Mar 21, 2009
SOURCE: Electrolux EWF 1074 get a lock icon
you need to hold the option and extra rinse buttons simultaneously for 6 seconds...you will see the padlock symbol go and then use your machine as usual
Posted on Aug 19, 2009
C11 isnt an error code. This comes up when you go into test cycle.
To get the error code out you need to turn the dial to any setting apart from the first on the right.
Then press and hold the start button and the button to the left of it and after a few seconds an error code will come up E??
What is that code?
