2004 Chevrolet TrailBlazer Logo
Anonymous Posted on May 14, 2008
Just leased an 08 SS
3SS Package, no nav or sun roof.
Turning in my 04 (they're paying the last month)
$3000 down including Tax, Title, dest, etc. everything.
$469/month
39 months
12K miles
Here's the rube question: Did I get took?
Oh, btw, NYC resident.
Thank you in advance.
Anonymous
Level 3:
  • Master 375 Answers
  • Posted on May 14, 2008
Anonymous
Master
Level 3:
Answers
375
Questions
6
Helped
274618
Points
1272
I just leased my 2007 TBSS w/ 3SS, Safe and Sound, no sunroof, BOSE, no nav.
MSRP was $36k
Had a 2006 TBSS and did a 6 month pull ahead (turned it in and didn't have to pay the last 6 months of that lease).
GMAC had a $1k incentive on leases so that acted like a cap reduction payment.
No security since I was turning in a 2006.
Paid 1st and last month for a total of $885.
Monthly payment including state tax of $40 is $440.
Hope that helps.
I have a 2003 monte carlo ss sun roof wont close and making popping noise
Sounds like the gears are bad in one spot. You can try to guide it closed with someone helping you as you pull or push it into place. Otherwise: http://www.theautopartsshop.com/auto+car-usa+parts/chevrolet+monte-carlo+sunroof-motor.html
tip
How To Install Replace Rear Power Window Regulator Nissan Maxima 04-08...
How To Install Replace Rear Power Window Regulator Nissan Maxima 04-08 1AAuto.com
on Mar 30, 2012 • 2004 Nissan Maxima
tip
How To Install Replace Remove Rear Door Panel Nissan Maxima 04-08 1AAuto.com
Radio freezes up then turns off and back on again some days it works fine other days not so well
I actually took a 06 Commander in last week with the same problem. We checked the windshield carefully, and then drivers door moldings and then blew out the drains for the sun roof.
It still leaked down through the drivers' side drain line area of the sun roof, around the window moulding, and dripped right in the vicintiy of the rear of the radio.
We finally found the problem by dropping the head liner down and using an inspection mirror with a flash light. We disconnected the drain line and plugged the nipple opening and poured a small amount of water into the sun roof pan and located a hole in the drain pan just above where the nipple is formed for the drivers' side sun roof drain line.
We could not see the actual leak source without the mirror and flashlight, as it was on the interior side seam facing away from the drivers' door opening.
Since carefully sealing the drain pan seam just a 1/4 above the drain hose nipple on the interior side, slightly above where the drain hose connects, the problem appears to be solved.
It appears to be a manufacturing defect in the plastic seam in my opinion. Could just be a faulty radio if your car doesn't have a sunroof, or a leaking windshield gasket.
3helpful
What does service b mean
The A service and B service is an oil change and a long list of inspections. Unless the service is covered under warranty, or this is a new car and you want some piece of mind, I suggest only getting the oil change. The rest of the "service" consists of someone looking for problems with your car. Here's what's included:
A SERVICE (~ $205.95 + tax) :
- Inspect and record tread depth, and correct tire pressure
- Rotate tires (excludes AMG, Sports Models, SLK, and vehicles with staggered wheels)
- Engine oil change and oil filter replacement
-Includes Mobil 1 synthetic oil
- Lubrication service
- Includes hood hinges, lock cylinders, striker
plates, sun roof tracks and top off all fluids
- Cooling system inspection
- Includes antifreeze protection level, hoses and
clamps
- Brake inspection
- Includes check of pad thickness and condition of
discs, fluids and lines
- Inspect heating and ventilation dust filter, replace if needed. (Replacement additional. Dust filter prices vary by model)
- Function check
- Includes warning lamps, headlights, exterior
lights, seat belts, windshield wiper and washer
- Inspect and lubricate throttle linkage
- Check and clean air filter
- Reset flexible service system counter
B SERVICE (~ $379.95 + tax) :
- Inspect windshield wiper inserts and service windshield washer system (Replacement of wiper inserts additional*).
- Inspect and rotate tires, record tread depth, and correct tire pressure. (Wheel balance additional*).
-excludes AMG, Sports Models, SLK, and vehicles
clamps
- Brake inspection
- Inspect heating and ventilation dust filter, replace if needed. (Replacement additional*. Dust filter prices vary by model)
- Function check
- Inspect front axle ball joints; check steering play and power steering clutch; and rear differential levels
- Inspect Poly V-Belt for condition
- Inspect starting and charging system and service battery
- Inspect climate control refrigerant
1helpful
Inalfa sun roof installed 3-29-04 in a Cad CTS 2004--will slide open but will not close all the way--any ideas on what to check?
may have slipped on the track mechanism and needs adjusted custom car shop may help with this..good luck..
Have 04 getz and sun roof wont work.stuck closed.has two control buttons,up and down and open close.thought cables jammed.popped motor off sunroof.motor only running one way.wont reverse.HELP PLEASE.
my apologies for delay in getting back to you.only just sorted this.turned out was the little control unit for sun roof causing problem.it is cable tied to the sun roof frame beside the sun roof motor and can only get at it by dropping the head cloth on one side.learned from a hyundi dealer the switches give a lot of bother,now and again the control units do too.many thanks.
Driver side sun visor on '04 Murano fall down.
a creative solution is to use velcro tape. a piece on the visor and a matching piece on the roof liner
Leasing used CLS
Yes Mercedes Definetily offers a lease program for them, HOWEVER, the dealers will try to push for you to lease a New-they will say cheaper-believe it IS NOT you can save Big Bucks going with a Brand Spanking Used Lease. Good Luck
My Ride.
2007 CLS 550 Blk/Blk AMG Package Fully Loaded MSRP $80,000
39 Month 10K $1178per month Toyal Out pf Pocket Was $3000.00
Leaseing CPO 2006 CLS55?
Just leased a 2007 CLS 550 withPO1 option through Apple Leasing.
MSRP: $71,815
Purchase price: $70,157
Down: $5,388 (includes 1st payment and TTL)
Length: 39 months
Payment: $1,079
Residual: 32,257
Apple leasing was great and I highly reccomend them. I started talking with National Vehicle Leasing. They offered a lower monthly price but th lease term is 60 months which they try to hide, obfuscate and misrepresent in every way possible.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
