SOURCE: ACER ASPIRE WON'T TURN ON AND RED LIGHT FLASHING
That is a motherboard problem .. The cmos battery is doing that ...
Testimonial: "thanks for your help!!"
SOURCE: acer aspire one - its died!!!
I have a problem with my Acer Aspire 3100: This is what shows on the screen;
Phoenix Trustedcore (tm) NB
Copyright 1985 - 2005 Phoenix Technologies Ltd
All Right Reserved
System BIOS Version: v2.83
VGA BIOS Version: ATI UMA V008.0501.017.000.18675
CPUO = MOBILE AMD Sempron (tm) Processor 3500+
640K System RAM Passed
446M Extended RAM Passed
512KB L2 Cache
System BIOS Shadowed
Video BIOS shadowed
ATAI CD-ROM: Optiarc CD-RW CRX880A
Fixed Disk 0 : Hitachii HT S541680J9SA00
Mouse initialized
Error
0280: Previous boot incomplete - Default Configuration
Used
Can anyone help me please?
Damie
SOURCE: Acer Extensa 5420 won't turn on, not a power/battery problem.
Just for the heck of it, try blowing out the cooling fan with some compressed air. If you have never cleaned it and the fan stops turning, the computer will go into a safe mode and not start up.
Ther should be a vent somewhere on the side of the laptop that vents hot air cooling the CPU. That is where you need to blow it out.
Hope it helps- just a longshot...
SOURCE: My acer aspire one won't turn on
"Download the latest BIOS, and put both
FLASHIT.EXE and the BIOS file in the root directory of the stick.
Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the
USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected.
Press Fn+Esc, keep it pressed and press the power button to turn the
AA1 on. Release Fn+Esc after a few seconds, the power button will be
blinking. Press the power button once. The AA1 will now initiate the
BIOS flash, do not interrupt it under any circumstances. After a while
the power button will stop blinking, and the AA1 will reboot shortly
after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
The Bios can be found from the Acer site.
Source(s):
http://macles.blogspot.com/2008/08/acer-aspire-one-bios-recovery.html
SOURCE: Windows 7 on aspire one AOA150, built in modem doesn't work
After installing Windows 7 and any other new applications, please ensure that you have loaded ALL the required W7 drivers for your specific Aspire One especially the CHIPSET supports driver (if not, plug-in devices and other inbuilt devices like sound, modem, usb or video will not work properly). Hope it helps. Let me know how you go!
