Hello! Here is procedure to replace the thermostat on your vehicle.....Guru.....Saailer
Accessory drive belt shield
Two power steering hose bracket retaining nuts and position the hose and brackets aside.
Cooling fan motor and shroud
3 A/C compressor bolts and position the compressor aside
Hoses from the thermostat housing
To install:
NOTE
Lubricate the thermostat housing O-ring with clean engine coolant.
New thermostat/housing assembly and tighten the bolts to 89 inch lbs. (10 Nm)
Hoses to the thermostat housing
A/C compressor bracket and compressor and tighten the bolts to 18 ft. lbs. (25 Nm)
Power steering hose, bracket and tighten the nuts to 89 inch lbs. (10 Nm)
retailerIdd874f148debugOnfalsecustomerId117788472vehicleId3089401
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
