If it is a matter of just the power supply failing, you can get a replacement. It is possible to remove the HD and place it in a new case with a new power supply, as well. However, if you suddenly smell something burning after that, you are on the trail to adventure. That might be a burnt out diode, easy enough for a PC repair shop to replace. Or, it might be something more serious and you would need an expensive data recover shop to get back your loss. You could call Western Digital customer service and see what they have to offer in terms of a power supply or make use of the following link:
Amazon com 12V AC power adapter for western digital elements WD6400EB035...
SOURCE: WD 500g hard drive computer cant read it
your hard drive is had it its common these size hard drive fail after a period of time but if you took the hard drive out static from you body could of damage the HD cannot be fix
SOURCE: when i plug in my external hard drive, the
u need to fix your external....it has a virus thats why!.....
SOURCE: WD Elements 1tb External HDD media files skipping
Try running Scan Disk and defrag. Otherwise use a program like SpinRite to do a low level scan of the disk.
Good luck
SOURCE: Elements by WD, AC Adapter Failed
There are replacement models for this 5V/1.5A power supply that the AD6008 uses.
One of them is made by a company called "Asian Power Devices" [APD] and their model number for the replacement for this particular unit is: DA-30C01.
I've seen them for sale on www.amazon.com for around $25.00.
Testimonial: "Thank you very much. That's eactly what I was looking for. I appreciate you speedy response."
SOURCE: External Disk WD Elements problem
did u format the wd 320 gb already
you have to format it first to work from it
Testimonial: "Thanks for the answer. I had already formatted the disk and transfer the folders. Thank you very much"
