Cameras Logo
Question about Sony Cameras
My Sony DV Direct VRD-MC5 is not recording audio thru the DV in/out cables. I have the Av>>>DV OUT setting to off on the Sony Hi 8 Handycam LCD screen and recording on AVCHD dubbing mode. What am I missing. All recorded discs look great but no sound. I have tried 3 different recordings. Pls help
Posted by richard_leib on
5 Related Answers
Anonymous
  • 99 Answers
SOURCE: LCD does not display image in record mode
ssue: The LCD/Electronic Viewfinder will not display an image or the image is distorted.
1. Press display (DISP.) button to turn the display on 2. If all troubleshooting has failed, please have your PowerShot A520 serviced
Posted on Feb 08, 2008
zimcloud
  • 135 Answers
SOURCE: What equipment do i need
You must connect the audio cables to your recorder too. The S-video just carries the (up to) 500 line picture signal.
Posted on Jul 28, 2008
Anonymous
  • 39 Answers
SOURCE: how can I export pictures from my computer to sony vrd-mc5
pls read this link :
http://www.crutchfield.com/S-gIufiXZNdM2/learn/reviews/20071113/Sony_VRD-MC5.html
hope it helps.
Posted on Dec 26, 2008
Anonymous
  • 10594 Answers
SOURCE: the dv/dv8 dubbing doesnt work. i
As it was told in chat session, Fixya does not provide phone chat/ assistance so far.
Thanks.
Posted on Aug 09, 2009
Anonymous
  • 1326 Answers
SOURCE: Bought a direct dvd recorder
Yes, the problem with electronics is the US uses NTSC and most other countries use PAL, it changes how the tape head alignes with the tape. You have to insure the device you have is both (most devices are) so try and get into the menu settings and see if you have a PAL/NTSC video selector option. If so change it to PAL.
Posted on Oct 27, 2009
2answers
I have a Sony DVD VRD-MC6, is there a way to connect my iphone to this model? I do not have a DVD Burner on my computer. Can I buy something to connect to my computer to make a DVD of my iphone videos
Dear Sir,
As I know Sony DVD VRD-MC6 do not have HDMI input so it not possible to record your video direct from iphone . but I phone has support to hdmi output thru iphone to hdmi cable and your Sony DVD VRD-MC6 has AV input so you need a one another device which call hdmi to AV converter it will work but your video quality will compromise.
If you want to record video form computer you need external dvd writer and one dvd burning software
After that you just copy your iphone videos thru usb cable and burn thru dvd burning software
How can i buy all the cables to the sony vrd-mc6
Yeah most common problem that consumers encounter. Recently I adquire one for my production company. yeah, I search around and the best site was amazon.com. Depending in your camera model you would have to chec if is rca videos plugs type or Dv to Dv, USB, or IILink, in my case from my Sony camera to the Sony recorder I use the Dv to Dv. Just chec your specifications to make sure.
Amazon.com has one of the most wide variety in cables that I have found in the internet one place and affordable.
I need a manual /sony vrd-mc5
http://sony.storagesupport.com/product/137#documents
Motorola VIP1216 DVR and Sony VRD-MC5 Connections for Recording?
I have the same problem currently. I have successfully recorded to the Sony CM5 in the past from my DVR, but no longer can. I have Comcast and wonder if they have changed the DVR firmware and blocked output. Also some broadcasts have something in the signal to stop recording. I got half of my program done, and can't record the rest on DVD. I will try to DVR local news, then record to the Sony, to see if it's a signal issue or something with the Sony. I haven't tried to record from a VCR.
Vrd-mc5
there is a firmware fix on the sony website
VRDMC5 System Software Upgrade Important Notes: New Features:
1) Allows VRD-MC5 to record video directly from a MemoryStick Duo memory card recorded using a Sony's MemoryStick Handycam Camcorder or an HDD/DVD Handycam Camcorder with Hybrid recording capability. Supplemental Operating Instruction
2) Allows VRD-MC5 to record video incrementally from multiple recording media in a Sony's Handycam Camcorder with Hybrid recording capability.
Improvements:
1) Fixes recording problem with no audio using a Digital8 Handycam Camcorder recorded through IEEE-1394 or i.LINK connection.
2) Corrects signal detections with a MiniDV Handycam Camcorder as copy-protected.
Version: 30R2 File Type: zip File Size: 4.11 mb Date: 01/06/2008 Download & Installation Instructions: Please download the attached VRDMC5 System software update file (SNDF8U30.DA2) and unzip it in a folder of your choice on the computer. Also print and read the attached instructions prior to executing the System Software Update.
Attachment Size VRDMC5 System Software Updater.zip 4.11 MB VRDMC5 System Software Update Instructions.pdf
No sound records on dvd
http://sony.storagesupport.com/dvdrw/vrdmc5dwn.htm
Version: 30R2
Release Date: 01/06/08
New Features:
  • Allows VRD-MC5 to support Sony's 1920 x 1080 AVCHD Handycam.
  • Allows VRD-MC5 to record video directly from a MemoryStick memory card recorded using a Sony's MemoryStick Handycam camcorder.
Improvements:
  • Fixes problems with no audio during playback on certain camcorders recorded through 1394 or i-link connection.
  • Corrects signal detections with some camcorders as copy-protected.
Instructions | Download Updater (4 MB)
2answers
Multi-function DVD recorder VRD-MC5
Update to my 1/8/08 posting - my recorder is working perfectly! I found the installation of the needed file quite easy and all is good in the hood.
Later
Top Sony Cameras Experts
W.L.
matt
matt
Darran Hatten
Are you a Sony Camera Expert? Answer questions, earn points and help others
