U need to check the crankshaft position sensor. The fuel pump will only have power for 2 seconds I till it sees a crank signal. It' controls the asd relay which turns on your spark and fuel
1998 Jeep Grand Cherokee 4WD 5.2L MFI 8cyl the Fuel Filter is part of the fuel pressure regulator assembly
which is located on the fuel pump module.The fuel pump module is located
on top of the fuel tank.
For 1998 Jeep Grand Cherokee 4WD
5.2L MFI 8cylthe Fuel Filter is part of the fuel pressure regulator
assembly which is located on the fuel pump module.
The fuel pump module is located on top of the fuel
tank.
Its possible that you are interesting in check the service manual ZJ-Secc-14-Fuel-System
Try resetting the asd "auto shut down fuse had a similar problem the jeep would crank but did not get spark or gas also check your fuel pump? and the asd relay may be bad it will prevent the jeep from getting no spark and will not fire some jeeps have security problems
Sounds like the fuel pump is going bad. There is an anti-drainback valve inside which may have failed. Have a more competent shop check it out. (or , just repalce pump)
