Nokia N70 Cellular Phone Logo
Posted on Sep 08, 2017
One sms has got stuck in outbox with deferred status because its battery died just while it was trying to send the sms.Later I tried deleting, moving to drafts & resending again but nothing happens. If I try to send it again it says sending failed and on deleting/moving to drafts it switches to deferred. Also tried resetting the phone but didnt help.What should I do?
5 Related Answers
Anonymous
  • 192 Answers
  • Posted on Jan 12, 2008
SOURCE: messages say resend all the time in d outbox
This is not a question of your phone's external it says for internal or workable memory of RAM. RAM is for providing room to running application. In your phone RAM is seems stuck and you have to empty it by formatting. For that backup your data and reset your phone by entering code string *#7370# and it will work again properly.
Anonymous
  • 1017 Answers
  • Posted on Feb 29, 2008
SOURCE: N95 - Pain in the Ar**
Make sure you're using your mobile service provider's settings and msg center number, and that your setting for reply is set to: reply via same center number to; NO
A
Anonymous
  • Posted on Apr 24, 2008
SOURCE: Call fails. SMS failure to send. Status 254.
I had the same problem. All you need to do is reset the phone settings :) Then it's back to normal.
Anonymous
  • 438 Answers
  • Posted on Sep 28, 2009
SOURCE: N95 8GB messages go straight to outbox (Failed)
call the customer care and get the message center number..re enter the message sender number given by them in the message settings....switch off n ON ur mobile..ur problem will be fixed...if the problem persists give a complain to ur service provider...it ll be a problem due to many messages at a particular tym!!
Anonymous
  • Posted on Dec 26, 2009
SOURCE: I can't send sms messages on my new sony ericcson satio
i have the exact same problem, please could u let me no if u got this fixed? iv tried everything :(
6helpful
3answers
I cant delete 1 message from my outbox.. cant even able to send it again...
Hi
If you want to delete message from outbox, Just Go to outbox defer sending then agen go to option select move to draft from there you can delete that message
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up //
My lg gd510 cookie pep is working slow
i recently send a msg and the msg sending is failed now that msg have gone to the outbox and i also try to resend but not working and there is no option to delete that outbox sms due to this a sms failed sign has come to my homescreen at upper side pls tell me how to delete that outbox sms
I was sending a text with a picture attached but it got stuck in the outbox as "Deferred" and I can't deleted...help please. what do I do?
try to turn off your mobile phone and after 5 minutes turn it back on.. and then try to delete the unsent text at your outbox..
1helpful
I sended sms to 16 ppls...15 msgs were sent perfectly bt d remaining one sms was failed to send....i went to outbox as it was tagged as DEFFERED...then i went to option and clicked on se....bt the sms is...
Try to reformat the memory. Dail code *#7370# I am telling this because this problem is not so rare in this model. This problem can be related with the Memory Card.
Thank you Sir, Have a nice day.
I have a text message that went through but it is still stuck in my outbox. How do I delete it?
go to options and move to frafts then delete it.. secondly there will be an option of defer sendeing .. do tht and thn move to draft and thn delete.
45helpful
4answers
Message Stuck in Outbox - and Cannot Send Text
First you have to cancel it and the under the more option move it to drafts and the restart phone
2helpful
2answers
Emails stuck in Outbox
Tools > Options > Mail Setup > Send/Receive > Clear check mark on "Schedule Automatic Send/Receive every .. minutes" > OK
Close your Outlook > Open Outlook again > Go to Outbox > Select The message > Send To/Move To Draft
Go to Draft Folder and delete it from there
5helpful
4answers
Text is stuck in my outbox
I had this same problem. Deleting and clicking "yes" at the warning screen would not remove the message from my outbox and the message kept resending for days.
Solution: In the Outbox, click "Menu" > Empty Deleted Items. Click "yes" at the warning. The message should now be gone from your outbox and your text buddy should now be able to regain sanity.
T-mobile credited back the resent text messages when I called them.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
