Spring is broken on the side that is 'slacked' without return tension. may be necessary to get underneath the stove chassis. move away from wall, carefully disconnect the gas fitting after turning off the gas spigot. Pull away far enough from wall to 'tilt' the whole chassis rearward to access the underside. Technicians use a 'jack' to raise stove....
SOURCE: Oven door hinges
It is tricky, it takes two people to hold door in place, put hindges into slots then fold downward towards the floor, the hinges will open all the way and it will snap back in.
SOURCE: dcs oven door unhinged
easy to install the door,before to remove check it how exactly the position of the door its a clip typr,or get the manual to see the procedure,open the door,pull open then if u see the hinge we have small lock in the hinge u psh it up the lock then slowly close the door,be care bcoz the hinge is powerfull,if u close the door see the hinge how to remove the door.
tnx gerbee
SOURCE: The hinge on my dcs-rgs-305 oven door broke. The
May I ask you question about your DCS range?
SOURCE: DCS 30 inch oven door fell off
please contact me at [email protected] for a solution to this problem.
