Question about GE JVM1790 Convection / Microwave Oven
I have a GE Profile convection/microwave oven, Model No JVM1790 BKC01. One of the plastic clips that holds the oven rack in place caught fire. Location of clip is top front right hand corner next to the control panel. The clip is still there but is badly burnt. Any ideas as to possible cause and if the solution is to have the clip replaced?
    Sergeant:
  • 268 Answers
Most rack support problems I have seen are from food splatter or grease getting around the support and even seeping behind it. Once it starts burining it must be replaced. It is really important to keep the area around them clean and dry and free from food splatter. A Microwave cannot tell what is on a plate or on the wall or rack support, and every food particle cooks each time the unit is run, until it turns to a carbon deposit and starts to attract the microwave energy and starts to ARC to that point.
Then it burns up the part it is arcing to. Have to replace support and scrub the area and inside of the cavity perfectly clean.
Posted on Oct 26, 2017
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: burnt hole in microwave
Is the hole actually bigger than it originally was or is it just empty because the rack support got burned up & discarded?
The rack supports / rack holders can be ordered. The part number is WB06X10140 (or WB6X10140) and they're less than $5.00 each. You can find them in stock here.
If you install a new rack support in the hole, then any gap or hole around it can allow grease to accumulate, and that can lead to arcing. But you can seal it safely & easily.
Once the support is installed and everything is squeaky clean and dry, you can apply a small amount of silicone caulk into the gap or hole.
Let it dry it overnight with the door open, then use a razor blade or X-acto knife to gently trim away any excess caulk.
That would be a really good fix.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
What do I do when the clip in the back catches fire while using microwave
NO KIDDING what is the clip for I have had several over the years and none had any clips
Feb 22, 2015 | GE JVM1790 Convection / Microwave Oven
My GE Profile JVM1790 convection microwave has issue. Was using the convection portion when a small spark and flame appeared and then went out and soot and smoke was all inside and now will not heat up...
Yep, that sounds very much like the heating element burned out. It happens. You should be able to get a replacement from the manufacturer's website... or there may be a list of repair centers in the manual - pick one & try to order the heating element through them.
Aug 13, 2014 | GE JVM1790 Convection / Microwave Oven
Bought house with GE Profile Convection Oven. Do not know proper cooking directions, nor how to work many of the features. Also no light bulb in it & would like to know which one to buy. Need manual t
GE has the manuals for most of their appliances on their site: http://www.geappliances.com/service_and_support/literature/ . Just enter the model number and click Submit.
The direct link to the manual for the JVM1790 Over-the-Range Convection/Microwave oven is here: http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40480-1.pdf . GE only lists the JVM1790CK, JVM1790BK, JVM1790WK and JVM1790SK.
I hope this helps.
Nov 10, 2011 | GE JVM1790 Convection / Microwave Oven
GE Profile convection JVM1790 will not heat. Everything else works but not heating. The oven is only two years olds. Any suggestions?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 16, 2011 | GE JVM1790 Convection / Microwave Oven
Will the template for JVM1790 be the same as earlier GE models?
Make your own template of the holes in the top of your cabinet and lay it over the new unit and see if they align. As long as your replacing GE with GE it probably will work.
Oct 04, 2017 | GE JVM1790 1000 Watts Convection /...
Convection Oven has stopped working
magnetron may be defective . replace d magnetron
May 29, 2009 | GE JVM1790 1000 Watts Convection /...
Ge profile convect oven in spanish and can not change to english
Press options on the key pad, turn dial to "idioma", press and turn dial to "ingles"
Feb 25, 2009 | GE JVM1790 Convection / Microwave Oven
Sparks when in use
Sonja, I'm not sure what hinges you're speaking about. If you are referring to the bumpers on the ends of the wire racks that are used for convection...move the racks away from the wall. Generally, you should not have anything metal in the unit when it is just microwaving....they are for convection use. You will not start a fire but you will shorten the life of the magnetron if you continue to allow the sparking condition.
Dec 05, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1790 Convection / Microwave Oven Logo
125 people viewed this question
Top GE Microwave Ovens Experts
Poppa Maddo
Poppa Maddo
William Miller
William Miller
Jimmy
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
