I just replaced the starter on my 2001 F 150 and had to use a 13 mm socket with a swivel and 3 long extensions. I reached the top and side bolts by going through the wheel well. You have to stick your head in over the tire to see the top bolt, but it was pretty easy to reach it with this combination. The side bolt I could either reach it from under the truck or through the wheel well, through the wheel well seemed easier using the swivel and extensions
1Raise the front end of the F150 off the ground with the floor jack. Place the two jack stands under the front portion of the F150's frame and then lower the truck onto the jack stands.
Open the hood and disconnect the negative battery cable end from the battery using the battery wrench. Push the cable off to the side where it can't accidentally contact the battery during the repair process.
Climb under the front passenger side of the F150 with the socket set. Locate the starter, which bolts to the side of the engine, where the transmission bell housing meets the back side of the engine block.
Unbolt the starter ground wire and wiring harness using the socket set. Move the wires aside.
Hold the body of the starter with one hand while removing the two starter mounting bolts with the other, using a socket set to do so. Never let the weight of the starter bear down on the loose bolts.
Pull the starter out by hand once you have removed both of the mounting bolts. Compare the old starter to your replacement, making sure they are physically identical before proceeding with the installation of the replacement unit.
Hold the replacement starter in position and thread the mounting bolts through the starter flange and into their mounts. Tighten them down with the socket set. Remember to never let the weight of the starter hang on the loose bolts.
Attach the ground wire and starter wiring harness in reverse of disconnection.
Lower the F150 off the jack stands with the floor jack and then reconnect the negative battery cable using the battery wrench.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
