OOOOoooKKKkk...
Please know your 'GLOW PLUG' should stay on 'only long long enough' to ignite the gas...
Your More/Less Dry function is probably a totally unrelated problem?
MAN you make this difficult !! Is yours a : Amana
NDE2330AYW
27 Inch 7.1 Cu. Ft. Electric Dryer??
In fact I give up ~ I WANT to provide SPECIFIC help for you but DON'T want to guess about your stuff.
Anthony
SOURCE: Admiral 6.5 Cu. Ft. Super Capacity Electric Dryer not drying load
does the admiral aed4475tq have a reset button it will not turn on it is only 9 months old
SOURCE: Our Amana ALG 331 RAC (bought 9/2001), super
Temperature selector switch on control panel may have bad contacts---
Temp sensor,in the temp control circuit---
Failure of the timer on the control panel---
Check that these components are working properly, if you are handy with a multi-tester you can track down the failing component.
Good Luck !
SOURCE: Kenmore Elite 7.0 cu. ft. HE4 Super Capacity Plus
Your drum rollers is in need of lubrication.
You can lube them with a high quality machine oil like 3inOne oil.
Please rate me
