Question about Zassenhaus 175 Manual Grinder
This turkish coffee grinder has been in our home for sixty two, it was in use untill the late sixties. I would like to use it again but the lower part (in which the powdred coffee acumulates) is now 'stuck' to the upper part (in which the coffee is grinded) and I cannot free it. What can I do to free the two parts?
Posted by heller686 on
3 Related Answers
Anonymous
SOURCE: Zassenhaus Turkish Grinder - handle
http://www.gittigidiyor.com/main/search.php?aramakategori=&aramakelime=kahve+de%F0irmeni&submitit.x=0&submitit.y=0&submitit=ARAMA&search_type=detail
Posted on Mar 22, 2009
bcarson750
Bruce Carson
  • 5 Answers
SOURCE: coffee grinder will not turn on
I recently had this same issue - it turned out that the lock switch no longer engaged because the spring came out of alignment after the unit was dropped. Chances are you have a similar issue. You can test this by using a small screwdriver to press down on the safely latch and then pressing the ON/OFF (careful of the blades!!). then you can easily fix it.
Posted on May 16, 2010
Anonymous
SOURCE: My Barista Burr Coffee Grinder suddenly grinds too fine.
If it is any consolation, mine just did the same thing, now takes too long to grind and it is way to fine dispite a thorough cleaning by disassembly.
Posted on Sep 26, 2010
Instructions for gatoropoly
this sounds like a crude form of a game we used to play back in the swinging sixties of which i have no knowledge sorry .Myself being a person of upstanding i never indulged in this and other games at music festivals .
Dec 07, 2011 | Late for The Sky University of Florida...
Whatever the setting is at the grind is always fine. What can I do to re-calibrate the grinder?
Grind Adjustment Tools required: Large blade and medium Phillips head screwdrivers In order to adjust the grind, follow these steps (Refer to figure A): 1. Remove all coffee from the hopper. 2. Set selector knob to the finest setting (Espresso or Turkish) depending on the model. 3. Loosen both knob retainer screws in selector knob one turn only. 4. While pressing the bag switch, located behind the spout, press the START button so that the grinder will run during adjustment. 810 model - Press the ON or START button so that the grinder will run during adjustment. 5. With the grinder still running, turn the adjusting screw in the center of the selector knob slowly to the right until a slight clicking noise is heard. Immediately turn the adjusting screw to the left one grind setting. This is the finest grind obtainable. 6. Tighten both of the knob retainer screws. Once the ESPRESSO grind has been set (Turkish for Model 835, 875, 890), the other grind settings will automatically set correctly. 7. Press the STOP or OFF button. IMPORTANT: Always be sure the grinding burrs are not touching while the machine is running on the ESPRESSO/TURKISH setting. Otherwise serious damage to the motor may result. dr_buckhead.png
Nov 19, 2010 | Grindmaster 810 T Electric Burr Grinder
Just bought a used one, seems like the espresso grind is pretty course, is there an adjustment I can make?
To adjust this grinder turn the adjustment nob to the finest setting (ESPRESSO or TURKISH) Locate 2 small set screws on the adjusting nob. Loosen these screws (do not remove them) about one full turn. Start the grinder and, with it running, VERY SLOWLY and GRADUALLY, turn the CENTER adjustment screw clockwise until you begin to hear the burrs begin to touch (whirring sound). Back off the center screw about 1/16 of a turn, shut of grinder and re-tighten the set screws. Then try the grind on DRIP or there about for brewed coffee.
May 21, 2010 | Grindmaster 495 Electric Grinder
With the dial turned to "Turkish" I still get a very course grind. How to adjust/fix?
On the adjusting knob there are 2 set screws (outside of the center) and an adjustment screw (the one in the middle). First make sure the LARGE screws on the side of the SELECTOR plate are tight. Start with the selector on Turkish, with the grinder OFF loosen the set screws about one full turn each. Leaving the selector on Turkish turn the grinder on and gradually VERY SLOWLY turn the center screw clockwise. Eventually you will hear the burrs inside touching. After they touch back of the center screw about 1/8 of a turn. Tighten the SET SCREWS tight as they may allow the grinder to go out of adjustment if not tight. Test the grind with very little coffee and throw those grounds out. Then grind and brew! If these grinders are adjusted too fine you may have problems with the grinds not falling and may back up.
Apr 26, 2010 | Grindmaster 810 Electric Burr Grinder
My speedometer is stuck at sixty but when i go it will move but wont go lower then sixty
you either have a bad speed sensor or your speedometer head is bad
Mar 16, 2010 | 2004 Honda Civic
How to calibrate my Bunn grinder.
It would be easier to pick up the manual in the commercial section under products from bunn.com, rather than me explaining it.
You have to loosen the nut on the adjustment wheel, then pull out slightly and turn towards coarse a few numbers, then push back in and turn grinder on and slowly turn toward fine, until the burrs slightly touch, you will hear a little metal on metal, at that point turn the grinder off, back off about slightly, then pull out adjuster and turn it to Turkish and tighten screw.
Mar 13, 2010 | Bunn -o-Matic G3 (3 lb. Commercial Coffee...
Zassenhaus 175 Manual Grinder Logo
51 people viewed this question
Top Zassenhaus Coffee Makers & Espresso Machines Experts
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Ross Keen
Are you a Zassenhaus Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
