SOURCE: Bosch SHY56A Dishwasher
if the door doesn't shut, the push buttons should not work. that way you are not running your d/w with the door open. check the door latch, as it seems to be malfunctioning. if the d/w still does not work, replace the door latch.
SOURCE: Clean light on dishwasher won't stop flashing
yust reset press heated dry-normal-heated dry normal-and it will work 100% remember that code it is reset code for wirpool quiet partner and many other models
SOURCE: control panel is locked. no buttons work when pushed
Try unplugging the machine and wait 5 minutes. Plug it back in, the problem should clear.
SOURCE: My Trionr XL dishwasher will not run. I push the
It sounds like your dishwasher might be locked. You unlock the dishwasher by pressing the "heated dry" button for three secs. and then releasing it, that should do it.
SOURCE: electrolux dishwasher all lights blinking and wont
Remove the toe kick by loosening 2 screws. There is a panel there with little lights that correspond to specific problems. The light that is on will correspond to the problem that the dishwasher has detected. Correct the problem and you should be good to go. I have no idea why this is not in the instruction manual. A common one is that there us a leak that the dishwasher has detected, normally in the drain pipe.
