Question about RCA Lyra RD2315 MP3 Player
I have a RCA mp3 version 1.67 and I can´t realize the formatting anymore because my pc says that I don´t have the rights to formate...It´s also not possible to eliminate the songs with teh pc and when I try to eliminate the songs manual the mp3 shuts down.... Please hlep me!!
6ya staff
SOURCE:
Anonymous
  • 75 Answers
SOURCE: error??
Try using this it worked for my m4002a. It's the firmware update software.
http://download.rcaaudiovideo.com/downloads/autoupdater.exe
After downloading that just follow the instructions that pop-up with the program.
Mine wouldn't do anything before i tried this and afterwards it's been working without a problem.
Posted on Jan 02, 2008
Anonymous
SOURCE: rca opal mp3 M4008A
Make sure the hold button on the right side of the player is pulled down away from the arrow.
I had this same problem today one I move the hold button, it rebuilt the database and
went into the menu.
hope this helps
Posted on Jan 17, 2008
Anonymous
SOURCE: flash errror
I was having the same problem as the rest after hooking my RCA S2001 MP3 player up to my new computer that is running Windows Vista Home. I did the following to fix my MP3 player on my old computer which is XP Home.
I fixed my player by loading the latest firmware version (1.5 at this time and can be found at http://www.rcaaudiovideo.com/product.aspx?product=124&post=6 ). After you load this application to your computer you access the update device application from the start menu/programs/RCA digital Audio Player/Jet/Update device. One thing that I had to do that had not been mentioned yet in this forum was selecting "Format data area"
Doing this wipes your device completely clean but it allows for you to keep using the device. The update device program will give you additional information after the update and format.
This should fix your device if not contact RCA through the same website above to ask additional questions.
Posted on Nov 07, 2008
Anonymous
SOURCE: formatting of RCA EMUSIC 1 512MB
i try to erase/format my current music data but my computer get hanged. the files are still there when i access it in my computer but when i what to use it using my headphone, it's gone. can u help pls. my mp3 is still very new.
princerwin
Posted on Nov 20, 2008
Anonymous
SOURCE: UMS Device Format
drop it from about 2 ft off the ground onto a hard surface like a wood floor. got the advise from this website actually.i was doubtful,but desperate. it works now!
Posted on Nov 24, 2008
My mp3 is not charging my computer doesn't recognize my mp3 anymore
Just follow these steps below:
To format the mp3 player.
Go through: Setting>Control Panel>Administrative Tools>Computer Management>Disk management>
Try to format it with fat files system or the file system you are accustomed with.
hope this help you
Regards
uttam
Jan 12, 2010 | RCA OPAL M4001 MP3 Player
I need reformat my RCA MP3 I don't know how, somebody can help me.
This should be a simple exercise (similar to formatting a floppy diskette) but make sure that you backup/copy all your existing files (including hidden system one) to your PC/Laptop first! - Connect your MP3 player to your PC (as required to back up your files) - Your MP3 player will show as a drive under 'Computer' in Windows Explorer: - Make sure that you have clearly identified the MP3 drive single click on the drive and browsing the mp3 drive content. - Now use the context menu by 'right-click' the MP3 drive -> select 'format' and click on it - Select FAT32 (or FAT16) as the file system for your MP3 drive if not defaulted / I suggest NOT USING QUICK FORMAT for a clean drive - Proceed carefully! PS. IF ENSURE, GET EXPERT ASSISTANCE FROM A PC SAVY FRIEND!
Dec 18, 2009 | RCA S2001 MP3 Player
I can't get certain songs to delete off the mp3 player. I'd like to delete all songs and start over.
connect it to your pc and use the format option to completely wipe the memory, connect to the pc Start, Computer, Right click on the mp3 player icon and select the format option.
Dec 02, 2009 | RCA OPAL M4001 MP3 Player
RCA MP3 Player will not get pass initializing
this has happen to me they are never the same agin you have to plug it in and get it to conect to the pc go to my comp right click rca and find format
Aug 12, 2009 | RCA M4204 MP3 Player
RCA Pearl TH1602-A default formatting
first of all, you need to be running these tests on a FAT16/32 bit machine running windows 95/98. second, right click on the device in my computer -> properties and at the top it will state the format:
File System: FAT32
The device always retains its factory settings/formatting until it is plugged into a computer, just by having it plugged in a .ini file is created and settings are stored in it, including file name, system and usually the format version.
If a user re-formats this device, they may have (assuming they excel in computers as i do...) the knowledge to edit these settings. Good luck
Mar 30, 2009 | RCA TH1602 MP3 Player
An mp3 player
connect the player to the pc1.gif,
open my computer1.gif, look for the disk icon for the player.
right click that icon, scroll down to format.
Mar 10, 2008 | RCA S1000 MP3 Player
Flash errror
Jan 06, 2008 | RCA JET S2002 MP3 Player
Rca opal m4002a
trouble - this player is not MAC compatible - you will always get that error
everyone else -
The Opal has a reset hole on the back of the unit in which a toothpick (non metallic) can be inserted to reboot the player.
If this does not work, I suggest that you reformat the player by using the WindowsTM format command on the unit. To reformat the memory
  1. Right click on the device within the Explorer or My Computer window
  2. Select the format command (full format) to reformat the internal memory of the device.
  3. Reinstall the firmware from http://download.rcaaudiovideo.com/downloads/opal_fwutility_v2.3.0.exe
Sep 19, 2007 | RCA OPAL M4001 MP3 Player
Formating
Jun 08, 2007 | RCA S1000 MP3 Player
RCA Lyra RD2315 MP3 Player Logo
26 people viewed this question
Top RCA Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
