Question about KDS Visual Sensations 190 (White) 19 in.CRT Conventional Monitor
KDS monitor screen turns black
My KDS 19 inch monitor powers up but turns black in about 3 seconds. Every time I power it up the same thing happens. I left it unplugged overnight but that didn't help. Have hooked another monitor to the computer and all is well. This is still under warranty, should I just return it or is there something that can be done to resolve the problem.
Posted by herbmadill on
Jerome Mackey
    New Friend:
    Problem Solver:
  • 13 Answers
If you have a digital stove then your digital board most likely is going bad.
Posted on Sep 27, 2017
richie46
    Top Expert:
  • 12,962 Answers
Return.
Vernice McDonald
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 9 Answers
So how long have you had it, and try to blow it out. Sometime they just need cleaning. If that don't work send it back before warranty run out
5 Related Answers
Anonymous
SOURCE: KDS RAD-5 monitor set up
THE POWER SUPPLY PLUGS INTO A WIRE STICKING OUT OF THE END THAT PLUGS INTO THE COMPUTER
Posted on Jul 24, 2008
Anonymous
SOURCE: Monitor Life
Instructions follow, RESULT "Replace and never buy a KDS USA Monitor again (less than 3 years usage)."
Posted on Dec 29, 2008
Anonymous
  • 3 Answers
SOURCE: kds model 780 monitor no signal, power button does not work
My monitor does the same thing at times and sometimes shows "No Signal" and at other times the screen will maintain the images but the backgound color switches to mustard yellow. In each of these cases I have been able to solve the problem by unplugging the power cord from the electical outlet for about three seconds and plugging it back in. I have a KDS model 780 LCD.
GOOD LUCK
Posted on Feb 16, 2009
Anonymous
  • 10 Answers
SOURCE: kds 917s lcd monitor
Yup, that's correct. The capacitors are very cheaply made. I recommend replacing them all if applicable. Before replacing them you must allow the capacitors to discharge. You can just unplug the monitor for a few days. A manual way is possible. I will explain that in the lower portion of this post.
Remove the screws on the bottom edge on the screen. When the bezel screws are out place your fingers on the top edge on the bezel and press down towards the desk/table. The bezel should slide down and off almost like a PC side panel.
Remove the screws from the LCD pane and place masking tape around the edges of the LCD panel. These edges are crudely cut and are razor sharp.
Once taped pull the panel upward slowly. Note the three cables connecting the panel to the metal box behind it. These cables are the sync/video and CCFL cables. 5 connectors in total must be carefully removed with needle nose pliers.
Once the panel is removed, remove the screws from the metal box housing the power converter and LCD driver. Inside are two separate boards. They are connected on the edge via a small socket/pin connector. Remove the screws holding the power converter PCB. (The one that connects to the power plug port.) (I must stress the importance as stated before. DO NOT remove anything until you allow ample time for capacitor charge to deplete. Or have discharged them manually.) Using an analog (Needle meter not digital) Volt meter set it to 50V or close to. Place both prongs on the corresponding pole of the capacitor. (One capacitor at a time) You will see the voltage spike then slowly decline. Once the current is at zero move on to the other capacitors.
The bad capacitors will have brownish matter oozing out. Use your discretion to replace the faulty capacitors. I'd suggest replacing them all. Before removing them note their polarity and capacitance.
Posted on Mar 24, 2009
Buddy Mcsparrin
  • 1684 Answers
SOURCE: My monitor stays on for 6 seconds
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htmYou can take the back cover off your monitor and look for the bad parts,replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and -connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 03, 2009
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
Monitor just won't stay on.
  • power chord may be faulty
  • check the cable that connects it to the computer correctly
  • may be an internal circuit breaker
  • check the ports on the computer
Oct 10, 2009 | Samsung 923NW 19" LCD Monitor
Screen goes black,power light stays green. display only stays on a couple of seconds
This happened to me and I was able to fix it. I cracked it opened and found a bad capacitor, bought a replacement at Radio Shack and I'm back in business. Actually using it right now to post this.
-Jon
May 27, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
Monitor Life
Dec 29, 2008 | KDS K717s 17" LCD Monitor
Kds model 780 monitor no signal, power button does not work
GOOD LUCK
Dec 15, 2008 | KDS Radius RAD-5 15 in. Flat Panel LCD...
I have an HPW19 wide screen monitor that goes to black.
I have the same monitor and it is only 3 month's old, the power lock button continues to fail and they have replaced it 3 times with the same issue, What a piece of ****!!!!
May 26, 2008 | HP w19 19" LCD Monitor
Monitors power problem?
Yup time 4 a new one :( .. Still ya had a good run 7 years is a great useage.. in my experiance.
May 02, 2007 | KDS Visual Sensations 190 (White) 19...
Monitor
Is there still power to the monitor or is the screen just black? Do you hear any sort of sound when it goes black? Does the time the picture goes out vary or does it happen after say "X" minutes/hours everytime? Do you have any power saving software activated that would cause the monitor blank out? Check display properties? Sounds weird but have you checked for any viruses or spyrus nasties? If its hardware it could be many different things. Let me know what happens. Good Luck Tim
Mar 15, 2007 | Sony CPD G420 19" CRT Monitor
Picture shows up for about 3 seconds then the screen goes black
XEROX 19" (XG92D) 5 MONTHS OLD...IT GOES TO WHITE WHEN WINDOWS TELLS IT TO TRUN OFF AFTER 2 HRS...IT GETS HARDER TO COME ON EACH TIME IT IS TURNED OFF. I TOLD WINDOWS TO NEVER TURN IT OFF. IF THE POWER GOES OFF I MUST TURNED IT OFF AND ON MANY TIMES, THEN IT COMES ON. I THINK IT MAY NOT COME ON NEXT TIME...
Sep 26, 2006 | Xerox XG-91D 19" LCD Monitor
KDS Visual Sensations 190 (White) 19 in.CRT Conventional Monitor Logo
111 people viewed this question
Top KDS Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
