Question about Sony Audio Players & Recorders
Wiring diagram or how to hook up
SURROUND SPEAKER +R- -L+ A CHANNEL NORMAL SPEAKER WIRE HOOK UPS SPRING LOADED TYPE. R L B CHANNEL PATCH CORD HOOK UPS. INPUT HAS - BLACK + WHITE L AND -BLACK + RED ALSO SAYS TO SPEAKER TERMINALS OF AMP. FRONT SPEAKERS +R- -L+ NORMAL SPEAKER WIRE HOOK UPS SPRING LOADED CLIP TYPE. HAS 120V AC OUTLET WONDERING IF I HAVE TO HOOK UP FROM TV OR VCR/DVD TO AMP TO PROCESSOR
Posted by TECATE on
5 Related Answers
Anonymous
SOURCE: How to add more speakers?
In the end I biwired the speakers and that's worked fine.
Posted on Oct 17, 2007
devocap
Devocap
  • 201 Answers
SOURCE: speaker wiring diagram
Hey there retgrunt, the information is at this location to download. the actual number on the guide is not the model you indicate, but the setup I believe is the same. I hope this helps Good luck!http://www.usersmanualguide.com/panasonic/dvd_home_theater_sound_system/saht70
Posted on Jan 28, 2008
Anonymous
SOURCE: Alpine Cdm- 7834 wiring help
bypass amp and run new wires to all speakers ,,,, will sound better .
Posted on Jun 17, 2008
Anonymous
  • 21 Answers
SOURCE: new Dual XIA3145 2/1 LED glows red, guide claims speaker problem
look at these and only these... power or ground...either your power wire has grounded out somewhere (ud be surprised) or youdont have a good enough ground....i would check the ground first....hopefully this helps
Posted on Jan 27, 2009
Anonymous
  • 290 Answers
SOURCE: needing wiring diagram for 1991 dodge dynasty le
here is what I found:
http://www.the12volt.com/installbay/stereodetail/715.html
Posted on Mar 26, 2009
What wire do i use to use all speakers at once???
that is surround sound system,,they hook up seperatly,,not together,,that would blow something,,,one wire to each channel and each speaker,,
Nov 04, 2010 | Coby CSP-94 Speaker
I can't get channel 3 to show satellite channels. They only show up on Video 3. I need channel 3 to work for surround sound. I checked wiring diagram and it looks like everything is hooked up the way it...
Hi there Guest, what you will want to check is what type of cable is hooked up to the TV. To broadcast on channel 3 it needs to be connected from the receiver by a Coax cable instead of RCA/HDMI/Component cables.
Tommy Faust
DISH Network
May 15, 2010 | DISH Network IR Remote Control
Do not know how to get regular T.V. hooked up to this system
try using the red White cables from back of tv to back of dvd player/receiver. Do the same with DTV/dvr or cable box. not sure if cable box has red and white cable outlets, however the DTV-DVR does, The quick patch is from TV to back of dvd (input audio)side,....that should work
Sep 26, 2009 | Coby DVD-937 5.1 Channel DVD...
Where can I get wiring diagram?
www.pyleaudio.com/manuals/PLMRA220-420.pdf
Jul 22, 2009 | Pyle - plmra220 - Marine 600 Watt 2...
Need help with my suround sound system
try wiggling the cords.i think it's open from the inside of the cord.sometimes attaching and pulling cords is the cause of no sound at all.check your cords for open.you can use a battery and a small lamp and wires.make a circuit of a lamp.then, get one wire from the small flashbulb and use it as a probe.the wire from the battery is the other.hook it up to your cords touching the one end ,like completing the circuit.if the bulb lights up it means it's ok and if not, your cord is open.
May 15, 2009 | Yamaha 5.1-Ch. Surround Sound Home Theater...
FINDING THE CORD TO THE SYSTEM FROM THE SPEAKER
From looking at the manual for your surround sound system
http://resources.jvc.com/Resources/00/00/93/GVT0150-001D.pdf
It looks like it just uses the regular spring-loaded clips to hold the speaker wire in place. All you need is regular copper braided speaker wire, nothing fancy. Then you strip about half an inch of insulation off the end of the wires, and pull back the spring loaded clip and put the wires in, then release the clip so it clamps down on the bare metal.
Speaker wire you can get from anywhere that sells the actual systems. I know places like Radio Shack (The Source by Circuit City) sells spools of it. Any other electronics store probably sells it too. It's common stuff.
Dec 13, 2008 | JVC TH-C6 System
Need one set of speaker wires.
If the wires have just bare ends plugged into spring-loaded contacts then you can get some twin lead from radio shack or walmart. Just make sure you match the colors from the stereo to the speakers
otherwise you might not get real stereo or surround.
Jun 02, 2008 | Sony DAV-S300 System
Only one centerback speaker
First off, I would like to say congrats on the receiver purchase - it's a nice one. To get true 7.1 surround sound, you will have to run another wire to another speaker. Any of these listening modes that you want to get are most likely using the capabilities of these 7 speakers. If you were to hook up one speaker to the two rear surround channels, you would be defeating the purposes of having that extra "speaker" and not really be gaining anything. If you really do want to access the 7.1 listening modes, you could always hook up another speaker and just hide it behind your TV, depending on your setup (essentially tuck it in a place where it wouldn't be heard, close to the receiver so that you don't need a long wire run).
In answer to your specific question, there would be ways of doing this, but just not all that advisable - you'd be posing a hazard to your speaker and/or the receiver. Like I mentioned, I'd recommend going through the trouble of running another wire and hooking up an additional speaker for the rear surround. If you're going to be using a Bluray or HD-DVD player, it'll be worth it. Hopefully this helps to somewhat answer your question.
Dec 19, 2007 | Onkyo TX-SR605 Receiver
How to wire in a cross over
You didn't say if it was active or passive, but here is both:
Passive crossovers are easy to install. By definition, the only type of connections they require are to your speaker line. They typically get installed between the end of the speaker wire and the speaker. Connection should be fairly simple, just like hooking up the speaker itself.
Now F-Mod crossovers modify the audio signal before it is amplified. They accept the patch cord from your receiver on one end, and then plug directly into the preamp inputs on your amplifier. They are also easy to install, and don't require additional wiring.
 An active crossover requires a little more work. You have to connect 12-volt power, ground, and a turn-on lead. The active crossover gets installed between your receiver and your amplifier. A lot of active crossovers have both speaker-level and preamp inputs, so they can usually work with either type of connection. The outputs will be preamp connections to your amplifier. Hope that helps.
Oct 05, 2007 | CTG 2 ft. Stranded Wire Crossover Cable...
MTX 502 2 chanel amp Pre amp problem?
Unless your amp is 1 (one) ohm stable then you may have fried it. When you attach a 2 ohm load across a bridged amp then you have effectivly placed each output channel on a 1 ohm load. Not a good thing in most cases. Try hooking up ONE speaker on one channel and one input to that one channel one at a time. Then switch the speaker/input to the other channel and see if you can get either or both channels to work independently. Needless to say you must turn the amp off before you make ANY change in the wiring.
Jun 25, 2007 | MTX Thunder 2-Channel Amplifier 502 Car...
114 people viewed this question
Top Sony Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
