Question about Samsung Cameras
My samsung digimax u-ca 401 does not capture pictures as they are. The monitor shows dark images even outside and its not to do with the settings. I think the lens has a problem because one time when this happened, a few taps on the lens brought the images bright. I have tried tapping again but nothing seemd to work. What do I do as I got this as a gift and do not have the option of returning it!
Posted by kud2 on
5 Related Answers
Anonymous
  • 64 Answers
SOURCE: Dark image....even using flash.
The problem here is likely the auto setting. Put it to sunny, clear day instead of indoor picture and you should be ok. Also, point it at neutral colored objects when you take the picture and allow it time to adjust by holding the button in partway before depressing it fully.
Posted on Jul 26, 2007
Anonymous
SOURCE: Flash makes my pictures too bright/too dark
u might want to try and put a coffee filter over your flash when you take pictures to make the flash less bright. it sounds really silly but it actually works.
Posted on Jan 07, 2008
t00nz
CameraR
  • 4738 Answers
SOURCE: Cannon PowerShot A85
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Feb 18, 2008
missjessd
SOURCE: samsung nv10 - bad image unusable
I phone up customer services and they said that the problem is likely to be mechanical, therefore, the best thing to do is to send it in to them to the address on the back of the instruction manual with a covering letter explaining your problem. You have to include a proof of purchase (such as a receipt/bank statement/confirmation email) and don't include any accessories when you send it (eg. cases, memory cards) by recorded mail.
Hope this helps, missjessd
Posted on May 02, 2008
Anonymous
SOURCE: overexposed photos in otherwise normal settings in casio ex-s500
I had the same problem with my EX-Z700. According to the repair guy, lots of Casio cameras have a problem with the flat cable that connects the shutter mechanism to the camera.
Posted on Oct 03, 2008
I need to get an operator's manuel.
At the website www.samsungcamera.com site you can download the manual and the driver for the Samsung Digimax 401 and the Digimax 4010 which are the same camera.
To get there go to the site and click on SUPPORT then at the bottom of page select page number 9 or in SEARCH type in 401 which will take you to the Digimax 401. DON'T FORGET THE DIGIMAX MODELS 401 AND 4010 ARE THE SAME. I proved it since I compared my 4010 manual to the PDF for 401 and page per page identical. You will have to select a language for the manual and assume also for the camera driver. I found that the Samsung site was not user friendly when I first used it looking for the 4010 model which is not listed but the 401 is there.
Hope this helps.
Dec 14, 2010 | Samsung Digimax 4010 Digital Camera
Hello, our samsung digimax S500 gives problems.
HI! ITs inevitable. Even mine does it when theres light. You will just need to find a perfect spot that has lesser light.
Sep 26, 2010 | Samsung Digimax S500 Digital Camera
Is San Disk memory card compatible with Digimax 401 ? I inserted one and got the message card errior.
SD Memory Card is compatible with your Digimax 401 camera. You just need to format the card.
Formatting a memory card
** This is used for formatting the memory card. If you run [FORMAT] on the memory card, all
images, including the protected images, will be deleted. Be sure to download important
images to your PC before formatting the memory card.
** If the memory card is not inserted, the internal memory will be formatted.
** Be sure to format the memory card if you are using a newly purchased or non-initialized
memory card, if it contains data that the camera cannot recognize, or if it contains images
captured with a different camera.
Formatting a Memory Card
1. In any mode other than Voice Recording mode, press the MENU button.
2. Press the LEFT/ RIGHT button and select the [SETUP] menu tab.
3. Select the [FORMAT] menu by pressing the UP/ DOWN button and press the RIGHT button.
4. Select a desired sub menu by pressing the UP/ DOWN button and press the OK button.
- If [No] is selected : The memory card will not be formatted.
- If [Yes] is selected : A [PLEASE WAIT!] message appears and the memory card will be formatted. If you ran FORMAT in Play mode, a [NO IMAGE!] message will appear.
Apr 12, 2010 | Samsung Digimax 401 Digital Camera
Sir..., i have the samsung digimax 401 digital camera..but when i insert sd memmory card showing "card error".. what's the problem..?
You just need to format the card in the camera. This will completely erase it so download any pics first using a card reader if necessary.
Feb 18, 2010 | Samsung Digimax 401 Digital Camera
Samsung digimax 401
the maximum amount of memory for Samsung Digimax 401 (or 4010) is 512 Mb
Mar 08, 2008 | Samsung Digimax 4010 Digital Camera
Outside pictures are all white.
I've got the same problem as misred. Is there anybody who knows how to solve this problem? Is it the CCD?
Dec 27, 2006 | Samsung Digimax S800 Digital Camera
Camera connection turns pc screen blue
A typical issue if the host PC's motherboard drivers were never installed. This and more at http://www.usbman.com Sadly, you didn't tell the make/model/chipset of the host PC so I can't comment further.
Sep 08, 2005 | Samsung Digimax 401 Digital Camera
Cameras Logo
71 people viewed this question
Top Samsung Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
