Sony CD Recorder disc problem
I recently did videography for a wedding and I used the church Sony CD Recorder to record the audio from the ceremony. I tested it before hand and it worked perfectly. Before the service began I started it, and after the service I stopped it, finalized, and it showed Track 1 at about 33 minutes long. But when I got home and tried to rip it, it wouldn't rip and just kept freezing Media Player. Then I tried to play the CD in a regular player and it won't play! The other disc that I did the test on rips and plays just fine! I neeeeed this audio. I haven't lost all hope because it's recognized as an audio disc, and it shows the track and the length. Any idea how to extract this audio or salvage any of the recording??? Thank you in advance!
Posted by toddsiegrist on
4 Related Answers
Anonymous
  • 30 Answers
SOURCE: Pioneer PD-F100 Constantly Skips to Next CD
the problem is not the laser, but the cable that connects the laser to cd board, it is cracked..and will break connection when moved out from its home position, i have replaced a lot of cabes for this model..i know it well
Posted on Jul 27, 2009
Duncan
Mike Duncan
  • 219 Answers
SOURCE: Philips CD Recorder
Have you tried cleaning the lazer lens with a cleaning disk?
Posted on May 21, 2007
Anonymous
SOURCE: Recording Errors
easy fella
sounds funny but ive got the exact same problem with the same machine but by the sounds of it philips aint that good for recording from a cd form from that model anyway!!
theres an old skool mix that i wana put out, but it will only play back on the recorder not on another source, ive managed to open the file up with nero show time on the pc thou and it will also play but just cant manage to convert to mp3 as the file is a wpl or something...
well annoying if you ask me
hpe thats helped a bit
Posted on Feb 04, 2008
Suresh Ayyar
  • 1481 Answers
SOURCE: Ripping audio CD-R's with Windows Media Player
use a different ripping software, the best is Nero and it does many other work by finetuing the audio tracks...
Posted on Dec 07, 2009
May be duplicate... I have 2 Denon cdr-w1500 recorders. They both started the same problem at the same time. I just cleaned them with q-tips and canned air (no q-tip fibers were left inside the units). ...
continuest uses of ant cd player or recorder will damage the eye. try 2 leave it upside down 4 a day 2 see if there is any dry spots in the eye. if not restart the cd player all day until it reboots
with a cd any kind. if unit is broken time for a dvd ,cd recorder/player. good luck buddy
Aug 24, 2014 | Denon CDR-W1500 2-Disc CD Recorder
Why is my recorder reading disc as data disc
you can only record on disks that are specifically marked for 'digital audio' you cannot just use any blank cd-r disk
Aug 04, 2014 | Sony RCD-W500C 5-Disc CD Recorder
I havee been trying to record services at church...and every time i hit record it says data disc....what am i doing wrong...please help me!!!!!
Manuals are always a good place to start.
You ARE using a data disc. It's literal. RTM and see that it only uses blank media that say "Digital Audio" on them.
Web search "Sony RCD-W500C manual"
Aug 09, 2011 | Sony RCD-W500C 5-Disc CD Recorder
Have not been able to find digital cd's. Are cd audios the same for use on philips 870
Philips CDR 870 is designed to RECORD with ONLY Audio or Music CD-R or CD-RW discs !!
The word(s) Audio Or Music MUST be written somewhere on the Cd disc or Cd Covers.
Computer CD-R and CD-RW discs will NOT Record on this recorder !!
My experience of GOOD Audio/Music discs : Philips,Sony,Traxdata,Verbatum
My experience of BAD Audio/Music discs : ALL unbranded discs, Maxell,TDK
Dec 16, 2010 | Philips CDR870 CD Recorder
Which cd-r audio do I buy.
when you buy cdr's to use with the recorder be sure to go and buy "cdr audio". You may have problems with certain brands. It really is hit or miss but Sony discs should be fine with this player but try to get a small number of cheaper disks and try to see what works well.
There is a small chance that one brand may sound better(or some people say) but I have never had one problem like this from one to another.
Mar 17, 2010 | Sony RCD-W500C 5-Disc CD Recorder
My philips cd recorder is not recording
the recorder philips cdr-778 put my 80 min sony cd-r audio in it start recording 20 second on track 1 go to track 2 for 20 second then stops goes to update some times it reads no disc when installing the disc we have been recording at the Church for the past 2 years
from clyde
Mar 02, 2009 | Philips CDR778 2-Disc CD Recorder
Rcd-w500c recorder
if you still have this problem let me know. I hooked this unit up to our sound board and it is working. so let me know and I will provide details on how ours is hooked up.
Gary, [email protected]
May 02, 2008 | Sony RCD-W500C 5-Disc CD Recorder
I am using it to record live in church, Do I need anything from menu?
You need to select the source,then just record and play IIRC.The manual is on sony's site.
Dec 19, 2007 | Sony RCD-W500C 5-Disc CD Recorder
Sony Cybershot D40
Ceremony meaning - inside church/hall -yes Insufficient light therefore long exposure in the auto setting. You should have moved up the ASA setting a couple perhaps
Aug 14, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
55 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
