Tip & How-To about Computers & Internet
It often happens that Windows boots slow. This can happen due to a number of reasons such as the presence of too many start up programs. However, the major cause of such boot delays is the registry corruption in Windows. Whatever the cause, the Windows slow boot is intolerable and there must be done something to fix it. Here you will find simple techniques which are tested in PCs around the world.
Step-1: Repair and Clean Windows Registry
You might not be aware that there is something very important inside the Windows. And due to the corruption in this internal component of the operating system, we experience Windows slow boot. The element which is referred here is the Windows Registry which contains information about all computer programs including the boot sector programs and services.
In order to have a quick Windows boot there must not be any corruption in the Windows registry entries. The best way to speed up a slow booting Windows is to use some authentic PC optimizer and registry cleaning tool.
Step-2: Reduce Start Up Items
Whether you are using Windows 7, Vista or XP, you must have some programs in your computer that start with the Windows start up. Sometimes too many programs running in background result in Windows slow boot. You can disable these programs through a start up manager tool in the PC optimizer software. Although there is a way to disable such programs through the "msconfig" function in the Windows but it is not recommended for all types of users since they can mistakenly disable the important Windows services necessary to run the entire system.
Step-3: Run An AntiVirus/AntiMalware Scan
Although not all boot problems are caused by the viruses or malwares but it is wise to run scans through these security softwares. However, it must be kept in mind that the registry repairing scan must be run prior to such scans for the best results to fix Windows slow boot.
The above guidelines will surely help you to make Windows boot faster. If you are looking for a complete PC Optimizer and Registry Cleaner software for a quick fix of your problem then it is highly recommended you run the Intel Software Partner, RegInOut scan here to fix > Windows Slow Boot.
