SOURCE: 1987 Ford Ranger that sparks but wont' start
try to replace the coil and all the spark plugs also make sure that the plugs are gapped right. that info will be on the evaporation sticker onthe core support in the front of the truck under hood. I think it is 0.004 not 100% sure on that. I hope that helps
SOURCE: does my 1987 ford bronco 2 auto,4x4 have a timing
Timing Chain system. Have you tried spraying a little carb cleaner in intake system to check if your getting fuel if it runs . Check fuel pump.Have you got spark?
SOURCE: The starter for my ford 460 stays running after
There is a spring in the starter that should cause it to disengage after the electricity is removed. Double check that the electricity is removed form the starter side of the solenoid, cause that is the easiest thing to check first. Then take the starter off and have it checked for free at your local auto store. If it seems OK to them it may be the starter is not the right one for the bell housing. If it sticks in to far, the starter gear may be stuck partly in the flywheel.
SOURCE: 95 F250 not starting
You said you tightened the battery cables, did you check the other end of the negative where it bolts to the engine. When you tightened the cables you also used a battery brush and cleaned the posts and ends?
Testimonial: "thank you"
