Question about Lexmark X6100 Flatbed Scanner
My Lexmark X6100 scanner is not scanning the entire image
Hi there
My Lexmark X6100 flatbed scanner is scanning most of my document, however several words and images are left out. Sometimes strange symbols appear on the new document. I am continuing to experience this problem despite attempts to scan onto MSWord, PowerPoint and Acrobat Reader etc.
Please help.
Posted by LaraF on
4 Related Answers
Daniel Lavoie
  • 9 Answers
SOURCE: Scan multiple page with X4550
The 4550 will not allow multi page scanning into a single doc using the provided software. You should try another scan software that is TWAIN or WIA compatible. Those should work okay if you are using a USB connection.
Posted on Oct 10, 2008
cowboytech
Lewis Fulkerson
  • 69 Answers
SOURCE: hello i have the lexmark all in one
Have you gone through the printer alignment procedure? This is especially necessary for scanning and copying. Also, make sure you're getting the document placed correctly on the scanner glass, and that the glass is free of dirt and oil. The impurities on the glass will cause the light to defract and make a mess of images.
Posted on Jul 17, 2009
Anonymous
SOURCE: my lexmark x5495 will not scan document if i chose
I have a lexmark 6500 and I have just changed the black cartridge and when I look it keeps telling me the left cartridge is incorrect but it is the correct one. Help someone. Please :)
Posted on Jul 29, 2009
Anonymous
SOURCE: Scanner not scanning complete image. Part of the
dell dp/n ocp580
Posted on Dec 20, 2009
I have a Lexmark 6150 and have misplaced my disk. I have a new computer and need to scan a document. I'm told I need to insert the OCR application located in my OCR directory of which I do not have. HELP!
The OCR application/software can only be installed using the installation cd. It's not available for download. I advise you to call Lexmark at 1-800-LEXMARK (1-800-539-6275) for the installation cd. They can better assist you with this request. They might be able to send you one for free. If you need more assistance, leave a comment. I'll get right back to it.
Apr 19, 2010 | Lexmark X6100 Flatbed Scanner
I have lexmark x6100 and i lost instalation cd how to install i dont have the draivers
go to lexmark website, look for drivers. download them.(save) run the down load- you'll probably get an install wizard. run it, and your lexmark should be back in service!
good luck!
Sep 29, 2009 | Lexmark X6100 Flatbed Scanner
I have vista and my x6100 lexmark printer not responding please help. i when on the lexmark website no help
It looks like the X6100 series of printers are supported on Vista starting with model # 6150 through 6190 Pro.
Based on the above information, I would say that the X6100 is not supported on Vista.
Jun 14, 2009 | Lexmark X6100 Flatbed Scanner
How do I get the printer to print
Click on the printer icon at the bottom right of the screen. It should bring you to the print queue.
Make sure that the print queue has been released. Sometimes the queue will be in a "Hold" status.
You can also release each print job by clicking on the job and directing the queue to send the job to the printer.
Don
May 20, 2009 | Lexmark X6100 Flatbed Scanner
Lexmarkx125 will scan larger pictures but smaller ones.
Here are some instructions from the Lexmark X63 which was similar to the X125.
The Lexmark X63 uses a sheet fed scanner, intended to scan 8 1/2 x11 inch paper.
  • To scan a document between 5 1/2 inches and 8 3/4 inches wide, center the document between the paper feed guides leading into the scanner and make sure the document is held straight,. Do not bend the document as it is fed into the scanner.
  • To scan photos or pictures that are 5 1/2 inches wide or smaller, you will need to use a flatbed scanner, or "mat" the image into a regular letter-size paper and scan the entire page. When the scan process is complete, crop out the picture using the AUTO CROP option in the Scan and Copy Control program or the photo-editing software.
Feb 27, 2009 | Lexmark Pro X125 All-In-One InkJet Printer
I am having a problem with my printer
Hi I found a link http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=X6100+MFP
i hope this helps
AJ
Jun 04, 2008 | Lexmark X6100 Flatbed Scanner
Installation x6100 scanner
Download The drivers from the lexmark website
M.I.B
Mar 24, 2008 | Lexmark X6100 Flatbed Scanner
Scanning Problem
Scanned image is unsatisfactorily cropped
You can turn auto-cropping off or adjust how the image is cropped.
To turn auto-cropping off:
From your desktop, double-click the Lexmark X6100 Series
All-In-One Center
icon.
The All-In-One Main Page appears.
2 Click See More Scan Settings.
3 Click Display Advanced Scan Settings.
4 Select the Scan tab.
5 Click Select area to be scanned, and then select a size from the
drop-down menu.
6 Click OK.
To adjust how the image is cropped:
All-In-One Center
icon.
4 Click the Scan tab.
5 Select Auto-crop the scanned item.
6 Slide the Tolerance bar to the left to crop less or to the right to crop
more.
7 Click OK.
Dec 06, 2007 | Lexmark X6170 All-In-One InkJet Printer
Lexmark X6100 Flatbed Scanner Logo
50 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
