Question about Panasonic Televison & Video
I own a panasonic pt61hx40b Projection TV. It started to make a clicking sound and when I looked in the back I actually saw a small flame. It looks like ti could have been a resistor or capacitor. I have pics. The location of the burn was on the main circuit board towards the front left (as seen from behind the TV) towards the screen. I need a schematic to find out what was there and see if it's possible to replace and repair it. Thank you
4 Related Answers
Anonymous
  • 11 Answers
SOURCE: Trying to identify a capacitor on the power supply board
IF you have the G BOARD part #A-1316-367-A it's:
1-162-133-00 CERAMIC 390PF 10% 2KV
IF you have the G BOARD part #A-1316-422-A it's:
1-161-754-00 CERAMIC 0.001MF 10% 2KV
Posted on Jan 04, 2009
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: Panasonic TV projector PT 4743G
yes the convergence ics will blow that resistor
Posted on Jan 21, 2009
SHAN BAILEY
  • 67 Answers
SOURCE: I need the capacitor value
well u can always go up on voltag but not dowm exe 50uf 25v this will work any voltag above 25v exmple answer 50uf 35v ur better u can get an idea of voltage the value is by +volt of surrounding caps also take multi meter read +voltag rember the formula i gave u hopes this helps you
Posted on Jul 25, 2009
Anonymous
SOURCE: convergance circuit board
TRY LOCATING THE COLOR CONVERGANCE IC CHIP ON THE BOARD , IT WILL BE MOUNTED TO AN ALUMINUM HEATSINK PLATE ON THE BOARD. LOOK FOR IT TO BE ATTACHED WITH A SELF TAPPING SCREW AND SPRING CLIP. THIS CHIP IS RECTANGULAR AND HAS 11 CONTACT LEGS SOLDERED INTO THE BOARD . ORIGINAL EQUIPMENT CHIP IS STK730-130 , AVAILABLE THROUGH SUBURBAN ELECTRONICS WHOLSALE FOR $4.59 +SHIPPIMG AND HANDELING. A TV REPAIR SHOP SHOULD BE ABLE TO SOLDER YOUR NEW CHIP IN FOR YOU,AND IF YOU HAVE SOLDERING EXPERIENCE REPLACE IT YOURSELF THAT IS WHAT I DID AND THE TV WORKS GREAT!
Posted on Sep 12, 2009
New Bulb... No Screen...
Ballast Board ,it is what turns Lamp on! Call Encompass Parts for Part or look them up online they have website. Call 1-800-638-3328 Ok I looked it up Part# is LSEB3062A1 which showed No Longer avaliable,So try UED 1-800-648-6657 and Look on E-Bay under Electronics For Ballast Board.
Nov 19, 2009 | Panasonic PT-45LC12 45" Rear Projection...
I need the capacitor value and replacement part number for C557 on board tnph0366 for panasonic pt61hx40b
Jul 25, 2009 | Panasonic PT-51HX40 51" Rear Projection...
Panasonic PT-45LC12......won't turn on
Its ballast supply issue that need to be replaced/ repaired.
Ballast supply drives Lamp in TV.
Jul 06, 2009 | Panasonic PT-45LC12 45" Rear Projection...
Small strip of video (about 3 in wide) in the middle of the scree
Just to be sure that I send you in the correct direction, does this strip look like a shrunken picture with no height? In other words is it a horizontal bar?
Thanks,
Dan
Mar 23, 2009 | Panasonic PT-47WXC43 47" Rear Projection...
Turns on then right off after a click saw smoke coming out of tv
check the board, maybe is burned , I have the schematics, if you want it, write me to [email protected], only I need the model of the board
Mar 03, 2008 | Panasonic PT-51HX40 51" Rear Projection...
Green Light blinks no picture
check that the thermistor/temp measuring device is suspect, no resistance across legs. There is a label there that says F701 see service manual
http://www.goodmans.net/get_item_th-tf117c_thermal-fuse-117-degrees-celsius.htm
I went here for a tech manual for the Panasonic
tv.
http://www.ManualsParadise.com
then ordered
Manufacturer: Panasonic
Part Description: FUSE
Part Number: LSJA0411-1
from
PartStore.com
it was mounted to the case that holds the lamp. had to remove the back panel, etc. Also think I had to splice in the fuse or something. was a while ago.
i purchased a NTE8115 from my electronics supplier, closest I could find.
Radio shack also has them.
remove the back cover and measure for continuity across the thermal fuse
above the lamp housing.
if open jump it wth a 5 amp fuse, be sure to close the safety switch with
the small blue lever then try to power on.
If comes on ok you will need to replace the entire ballast assembly to get
that fuse.
Panasonic does not have a part number for just the fuse on the PT40LC
series.
It is possible to cut off the fuse and replace with another but dont solder
Dec 27, 2007 | Panasonic PT-40LC12 40" Rear Projection...
I need a sevice manual can anybody help?
I think you may have seen this site, but just to be sure; http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html It looks very useful for you. these guys have a service manual and supplement for sale; https://www.manualsparadise.com/ShowProductsForModel.do?model=M77759179 also I saw a blog saying that you can actually order these from panasonic direct - haven't tried it myself Hope this helps :)
Jul 03, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Bad Ghosting Panasonic
It sounds like you may have a couple of defective convergence IC's, and maybe a couple of resistors. A fairly easy repair. Since you already have a warranty on the set, I would have it repaired and let the company know you haven't been too pleased with the picture quality all along. They may be able to tune it up a bit after repairing it to really make it shine for you. Panasonic usually makes pretty good sets, you could do a lot worse with some of the other brands out there.
Jan 20, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Televison & Video Logo
126 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
