SOURCE: Using JETCET Print with OKI C5200n Printer
The OKI 5200 is a 'GDI' or Windows only printer and does not support PCL or PostScript languages.
Most if not all of the printers listed support either PCL or PS or an inkjet based language.
I'm afraid you will not be able to print the the 5200 without it's driver loaded on the PDA.
If the 5200 supported PCL you would be able to choose any of the
Color HP Deskjets.
SOURCE: HP Photosmart C4380 All-in-One printer
check the ports first.. make sure that the printer is set as default ( make sure it has the green tick and the status "ready" or "online" on the printer icon in the printers&faxes. and if u want to connect it wirelessly, you have to install it as usb first before changing to wireless........
SOURCE: HP 7410 off line with Vista & HPM8000 computer
Once right click on the printer icon and make it online and then clear the print que and then download and install the patch from the below webpage.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-54112-1&lc=en&cc=us&dlc=en&product=391194&os=2093&lang=en
After installing the patch restart the computer and check for the result.
SOURCE: Cannot print with wirelessly networked printer
hi,
if printing from 2 other computer works fine, will i think its not an issue of IP address which changes somehow. but anyways, try to check if you still have other printer drivers under "PRINTERS" (see control panel). it should say HP Photosmart c6100 series. If you also have there a printer icon that says HP Photosmart c6100 series Copy1, try using it (right click on that icon and choose Set as Default Printer). If you only have HP Photosmart c6100 series under PRINTERS, try to right click, then choose properties. When Properties box is open, click on PORTS tab. then click on configure ports below. Try to type in the IP address of the printer under "Printer Name or Host name or IP address". make sure that you already printed network configuration page to get the exact ip address of the printer, Dont know how to print? do this.
PRINTING NETWORK CONFIGURATION PAGE
1. press setup, then scroll down and look for Network.
2. press okay on network, it will give you the first option "VIew network settings".
3. press okay on it, and it will give you the first option "Print network configuration page."
4. choose that and press okay. it will print the network config page. from this document, you will be able to see the IP address of the printer.
Please let me know if the issue is still not resolve so that i can go ahead and give you another possible solution.
Thank you so much.
adonscott
SOURCE: i have a hp photosmart
I have a new all-in-one. the way I do it may not be the most efficient but it works. I use Adobe Photoshop Starter Album 3.2 (Free).
Use the "File" tab to "get photos from scanner". It makes a copy in the "my pictures" folder under Adobe>scanned photos sub-folders.
Just find your picture, right click, select "send to">mail recipients and away you go.
You can also use the "share" option on the Photoshop toolbar and it places a copy of the item in the "outgoing email attachments" folder in your "my pictures" folder.
Hope this helps
Hi katrinavande, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
what ip address is the router ?
what ip address is on computer ?
what ip address is set up on the printer ?
what ip lease range does the router's dhcp server issue out ?
