Question about Yamaha RX-V661 Receiver
A fix for you...
The part number for the replacement bulb for your rx-v850:
VF402500
see here:
https://www.vancebaldwin.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=6557766
$1.40!
enjoy,
bsmt dweller
Posted by bsmt dweller on
2 Related Answers
petraman7
Scott Frye
  • 1175 Answers
SOURCE: i need a display bulb for a yahama rx- v850 av reciever
The display bulb is a 14 volt bead style lamp about 0.150 inches wide with wire leads. You'll need to cut the old bulb off the two -pin cable assby and wire the new lamp into the existing wires.
partsexpress.com
mcmelectronics.com
or
studiossoundelectronics.com should have lamps for that
Posted on Feb 04, 2009
Anonymous
SOURCE: i just purchased a yahama rx- v850 av reciever
ezraw,
I have same problem from same rec....
thanks I will make this a project for my EE friend at Radio Shack.
am also missing bass, treble and balance knobs off same unit? Any idea where to find. Also missing remote, can any universal remote work or do i have to find original?
thanks
Posted on Feb 19, 2010
Do I need to connect my older Fisher Turntable to a pre-amp before connecting to my Yamaha RX-V850?
No, you don't need a preamp if your turntable has a moving-magnet (MM) cartridge, it should work as-is! Happy vinyling =]
See page 27 of the manual:
Yamaha RX V850 User Manual Page 27
Aug 09, 2016 | Yamaha Rx-v850 Audio Video Receiver Black...
How to connect my lg lcd tv to yamaha rx-v850
Use the Component Out sockets (RCA sockets - Yellow , Green , Red yes 3 wires) on TV to Component In sockets on Receiver which is again 3 wires
Jun 14, 2015 | Yamaha Rx-v850 Audio Video Receiver Black...
Rx v850
Are they connected and turned on. First read the instructions they contain some amazing information.
May 04, 2014 | Yamaha Audio Players & Recorders
Yamaha rx v850 centre and rear speakers dont work
-- Are they connected and turned on. First read the instructions they contain some amazing information.
How do I connect the Bose Equalizer (for Bose 901 Series VI speakers) to a Yamaha RX-V850 RS? (not as a home theater) Thanks
If you get a second amp for the 901's you can have your cake and eat it in front of the TV too.
http://www.retrevo.com/support/Yamaha-RX-V850-Receivers-manual/id/320bh027/t/2/
Two solutions:
ONE: dedicated 901-RX-V850 stereo-analog-audio only:
If you want to have the Yamaha also support non-901's as the second set of Front Speakers, put the Active Eq in one of the three selectable Tape Loops. That way you can dial the 901 EQ out of the equation and select the 'normal' speakers for your Dolby Surround video experience.
Now imagine this:
TWO: 901's for the Front on a 100wpc stereo amp, your RX-V850 or a nice digital AVR driving center and rear, maybe 'normal' fronts, too
Get a nice 100wpc amp with its own volume control on eBay and slave it off the Yam. Remove the Front Pre-Main jumpers and place RCA Y-splitters in there so the pre-main connection out is maintained but shared with the Active EQ, which is in series with the 901's dedicated amp. Use the new amp's volume to match the 901's to everything else and you just have to turn it on or off to enjoy the 901's along with or instead of the 'normal' front speakers. You could even just disable them at the Yam.
Now for some boilerplate I created to get your creative juices flowing ij case you have a digital AVR in mind for the future:
Having a 901-based multichannel setup myself, I would highly recommend getting the Full Monte for video listening (below)...
In that case a separate stereo amp for the 901's would work. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out (or one of your analog Tape Outs) >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Then set the new amp's volume control (if it has one, mine doesn't) to something HIGH and run through your speaker setup routines on the Yamaha. After levels and distances are set the Yam will be the boss of the 901's. I recommend sharing or directing any LFE with them. With 901's don't even need subwoofers but they don't hurt.
I've done this in my own setup once. Turn the 901's around so the rear faces point into the listening area. Crank up Master and Commander and when the waves are crashing or cannon are firing you WILL FEEL A BREEZE from them. Now THAT is multi-media!
Jan 17, 2011 | Bose 901 VI Main / Stereo Speaker
I need a display bulb for a yahama rx- v850 av reciever
partsexpress.com
mcmelectronics.com
or
Jan 11, 2009 | Yamaha RX-V461 AV Receiver
I just purchased a yahama rx- v850 av reciever
if you dont mind a lettle customization, just go to radioshack and set your favorite color l.e.d. and wire it in, if you can find a specs diagram for your reciever, you might look up voltage and wattage of the bulb so you can get appropriate resistors for the led, and install that. itll last forever, cost virtually nothing, and its easy to do.
Hooking Up Wires
This should help you.
https://www.hifiengine.com/hfe_downloads/index.php?yamaha/yamaha_rx-v850_en.pdf
You'll need to register but it is free to do so.
Good luck! Login HiFi Engine
Sep 23, 2017 | Yamaha RX-V800 Receiver
Yamaha RX-V850 receiver
how can i hook a subwoofer into yamaha RX-V850
Dec 25, 2007 | Yamaha Audio Players & Recorders
Yamaha Receiver RX-V670
Parts list and exploded diagram of yamaha rx-v850 found free here:
https://www.vancebaldwin.com/shop/research_new/YAM/RXV850.pdf
Enjoy. They can get the bulbs for $1.40...
Bsmt Dweller
Sep 07, 2007 | Audio Players & Recorders
Yamaha RX-V661 Receiver Logo
130 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Will
Level 1 Expert
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
