Question about Rheem Heating & Cooling
Hi, I have the Rheem 3 stage advanced indoor air quality system and the Hepa 3.0 HRV. I need the manual for the Rheem 3 stage advanced. To confirm the filters and lights were put in correctly. I have the hepa 3.0.manual Can you assist me w/ this? 541-683-8888 Thank you!!!!!
Posted by patrishk_hr1 on
5 Related Answers
jerryg50
Jerry Greenberg
  • 1691 Answers
SOURCE: how to find the carbon filter to change it and how we should clean the hepa filter on our
You should contact Honeywell to find out their parts rep for your area. I don't think you will find these parts in the regular hardware store.
Use Google to find the Honeywell home page, and work from there.
Jerry G.
Posted on Apr 27, 2008
Anonymous
  • 254 Answers
SOURCE: I'm working on a Weatherking
It is a filter, probably to collect either moisture or contaminents. This unit most likley has a fixed metering device oriface where the evaporator connects to the line set.
Posted on Aug 31, 2008
Anonymous
  • 540 Answers
SOURCE: Brand new Hunter Quietflo 90
H EY< check to see if all doors are on tight. then check for power from that socket,by plugging something else in it to see if the wall plug got power,I've e-mailed the Manufacture for the webpage and telephone # for you and they want your order # and did you buy from them here's the telephone #(800) -881-7787 & the webpage is iAllergy.com.and chat with the customer care.
Posted on Sep 03, 2008
debbily
Debra V
  • 101 Answers
SOURCE: WindTunnel HEPA Filter won't spin
I just fixed my HEPA filter not rotating!!
It involves taking apart the vacuum HEPA area. All screws are the same size. There are a LOT of 'em. Really straightforward putting it back together too.
ok, once you take the HEPA canister area off the vacuum, careful with the wires! Unplug them from the controller board. You open up the HEPA chamber by removing more screws until you see where the motor that turns the filter is mounted on the side. Remove motor from the green chamber. Note where the washer goes. Once the motor is off, you'll see that the center hub that drives the HEPA filter is rounded out. What I did was jam little bits of aluminum from a pop can into the space between the circle and the square to force the walls back to square. I started by folding a little piece of aluminum over and over so it was about three layers thick. Jammed that in. That wasn't quite enough thickness so I shoved another piece with it. If you can find something that is about 4 times the thickness of a pop can aluminum, that'd probably work too. Slight wedge shape on the tip would help. Any sort of tiny shim.
To test your work, just put a couple of holder screws into the HEPA cannister housing, plug in the cover/switch, plug in the HEPA moter. Turn it on for a few seconds to make sure the filter turns. Then you can add more thickness to the hub or put things back together.
Posted on Oct 12, 2008
Anonymous
SOURCE: Replacement HEPA filter for Danby DHCC6020?
We just ordered from Danby... call 1-800-26-danby... it's part number 6020.02
Posted on Jan 15, 2009
THERE IS A MAIN AIR VENT IN THE CENTER CEILING THAT BLOWS COOL AIR. SHOULD THE SMALL VENTS IN OTHER ROOMS WORK TOO? & WHY NOT?
Hi Missy:
Your question is in the cars and trucks section, but it sounds like it is about your home ventilation system.
I'm thinking that you probably have an HRV (Heat Recovery Ventilation) system that you are asking about.
- Even in the non heating seasons, these units are intended to operate for 20 minutes of every hour, when humidity gets high, or when a manual timed switch is pressed for bathroom exhaust fans.
- Inside air from the bathrooms and possibly kitchen is sent through the HRV to the outdoors.
- Fresh outside air is drawn in through the HRV at the same time and distributed throughout the home via the vents you are referring to.
- These devices are designed to improve air quality in the home, AND to reduce costs in the heating season.
- Additional devices like furnaces, air conditioners and heat pumpscan be part of the system so it can get complicated.
-If possible, I would be trying to check with the builder of your home to find out what system had been installed.
Hope this helps.
Ted (Retired Building Inspector)
Jul 06, 2015 | Cars & Trucks
Rheem error codes
error code 29 is a high pressure open. possible causes are dirty indoor or outdoor coil. indoor or outdoor fan not running, liquid line Freon restriction, or to much Freon in the unit.
Jul 30, 2014 | Rheem RPRL048JEC 4 Ton 16 SEER Heat Pump...
Is there a way to test indoor air quality in my home ?
Yes. There are few many indoor air quality testing & building performance firms that do air quality testing. Some specialize just in this discipline.But keep in mind that even the best HVAC system needs fresh air from outside. Also i've heard a thing called a sling psychrometer. it measures moisture content in the air. you want 50% humidity. all HVAC companies have them.
Dec 23, 2013 | Building Health Check Llc Indoor Air...
I have been looking to buy an air purifier and people keep telling me to get a HEPA. What does this mean?
HEPA is a type of air purifier. It stands for high-efficiency particulate air. To qualify as a HEPA filter by government standards the filter must remove 99.7% of all particles larger than 0.3 micrometers from the air. The following site lists the top 10 HEPA purifiers available online - http://www.air-purifiers-america.com/AP101_top10.asp.
Jul 12, 2012 | 3M "Replacement Filter, 11 7/8 x 18 3/4"
After 5 minutes the unit shuts down with an error of C8 13.
Typical manual shows error C8 13 on page 33:
Has to do with air intake, air quality, air shortage, air filter, or internal parts, or combination of internal and external factors
http://waterheatertimer.org/pdf/Rheem-RTG74IndoorOutdoor_owners.pdf
Typical manual also shows regular maintenance on page 29.
The word maintenance is used throughout manual.
Tankless are prone to lime build-up and should be de-limed each year, and cannot be exposed to more than 11 grains of hardness in the water.
Open following link to see list of UN-answered fixya questions about Rheem tankless:
Older question tend to have answers that might be helpful for you to read.
http://www.fixya.com/tags/rtg_74pvn
Research shows that regular de-liming will not restore full efficiency to tankless water heaters:
http://waterheatertimer.org/pdf/Battelle_Final_Report.pdf
Since all costs are energy, if you get tired of messing with tankless.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
http://waterheatertimer.org/images/Compare-water-heater-parts.jpg
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 01, 2011 | Rheem Paloma PTG-74PVP / RTG-74PVP Liquid...
I have an HRV system and want to know if it is possible to run a heat pump through my HRV ducts in the ceiling?
Hi, can you tell me what kind of heat recovery ventilation system you have? Is it a Honeywell, Lennox, ect.? Also tell me about how you have it set up as far as the duct work you are talking about and what kind of heat pump system you plan to install. If you tie your central air heat-pump ducts into the HRV ducts, it will interfer with the air flow. If you will, please tell me what you plan on doing as far as installing what to your home? New duct work for a new central air heat-pump unit, or what, so I will have some idea on what you are doing. Thanks so much. Contact me through my user name below.
Sincerely,
Shastalaker7
Apr 13, 2010 | Heating & Cooling
Have a large new house with lots of vinyl clad wood double hung windows on a lake temp today this am is 0 F we have a HRV system house temp is 66 downstairs and 58 upstairs heating with a heat pump and...
Really not efficent to run a heat pump at those temperatures. Below freezing is not good for the compressor in the outside unit. The humidity in the house with the low temp. is causing the condensation on the windows to freeze. Kinda like an air conditoner does in the summer without the freezing humid air from the house goes over the cold a/c coil and the moisture condensates on the coil running down to drain pan. raising the temp. in the house and lowering the humidity should help. I would also recommend running the electric heat in low outside teperatures.
Dec 17, 2009 | Aprilaire 600 Humidifier
Airconditioning is making baby cough and nose run would a humidifer help? will a humidifer make the room hot?
You may need a HRV/ERV installed. Depends on your indoor air quality(IAQ). It may be allergies. I would talk to a reputable heating/cooling contractor in your area to evaluate your system, recommendations.
Nov 21, 2009 | Aprilaire 600 Humidifier
Is EDF5 required to have intermitant running of Fantech HR 2005R?
The SHR2005R will turn on the furnace Blower if the furnace is not running to circulate the fresh air. The reason the furnace will not trun on the HRV is, the purpose of the HRV is continuous Ventilation in your home. It should not be turned off when your furnace is not running. That why Fantech has not design the HRV's to run that way. I hope this helps.
Jan 18, 2009 | Fantech EDF5 Intellitek 5MR Control for...
Heating & Cooling Logo
71 people viewed this question
Top Rheem Heating & Cooling Experts
Lawrence Oravetz
ray gallant
 Russ Hill
Russ Hill
Are you a Rheem Heating and Cooling Expert? Answer questions, earn points and help others
