Dropped packets I have a comcast as my internet supplier and AT&T for VOIP Comcast=Motorola Surfboard Modem 5120 AT & T D-Link Model DVG-5102s Comcast says the dropped packets are AT&T's problem and AT&T says its comcast. Meanwhile there is dead silence in the middle of a conversation for up to 10 seconds and incoming calls cant be answered because the caller cant hear you and vice a versa. Any ideas?
Posted by Rocco T on
  • Jeffrey Pemberton
    Jeffrey Pemberton May 11, 2010
    Hey Rocco - can I ask you where you live? It matters as far as who's problem it is. I also have some software that will prove who's to blame and I can also tell you how to check a few things yourself.
2 Related Answers
Anonymous
  • 457 Answers
SOURCE: Motorola 5120 Surfboard
Yes it can happen after a reinstall.. You will need to go into the computer ie take the back off. Pull the modem out and put it back in in another slot exact to the one you pulled it out of. Try it again it will no doubt read this time.. It can only be done this way if you try to manually install a moderm it will load the standard one NOT your Modem. Goodluck!
Posted on Sep 09, 2007
Anonymous
  • 33 Answers
SOURCE: internet won't recognize our motorola surfboard
You need to register your modem with your cable provider. They will need the MAC address which is on the side or Bottom of the unit.
Posted on Jan 13, 2010
Will motorola Sb6140 work with century link internet
centurylink looks like its dsl (which uses a home phone) ppoe
comcast uses cable connection (like cable tv) don't think their compatible
call centurylink to be sure
Feb 22, 2016 | Arris Surfboard Extreme Sb-6121 Docsis 3.0...
Does the motorola surboard sbc6580 modem have phone connetion
Hello:
Neither the SBG900 nor the SBG6580 have a phone jack.
A cable modem with a phone jack is called an eMTA (Embedded Multimedia Terminal Adapter: Cable modem Wikipedia the free encyclopedia.)
Most cable companies will only have one alternative to their own equipment when it comes to eMTAs. For example, Comcast only works with the Arris 722G: Customer Owned Arris 722G FAQ Comcast Help and Support Forums, and they'll insist that it can only work if you bought it from Best Buy.
If you wanted to keep your SBG900 or SBG6580 and have VOIP phone service, look into a service like Ooma.
May 03, 2014 | Arris SURFboard SBG900 Wireless Router...
Will this work with Comcast broadband and Windows 7?
This modem will work with Comcast High Speed Internet.
You will have to contact Motorola for drivers for the Windows 7.
It does matter how fast your internet speed is,anything faster than 20meg,will need a Docsis 3.0 modem.
Jan 13, 2011 | Arris SURFboard SB5101U DOCSIS 2.0 Cable...
Would like to connect a fax but only port 1 or (tel 1) port 2 does not work, should i send back to comcast or reset modem
There is nothing wrong with your modem. Comcast charges extra for a second line. Depending on your model of fax machine, there should be both an input ond an output on the back of the fax machine. Plug the fax machine into line 1 on the modem. Then, plug your phone into the input on the back of the fax machine. If you fax does not have both in and out, then you can purchase a "Y" phone line adapter from your local electronics store.
ps. VoIP is a digital line... Facsimiles are analog signals... Sending analog signals over digital lines is not recomended. If you are wondering "why?" (and understand tech jargon) VoIP is sent via UDP, which is a connectionless protocol (does not retransmit dropped packets) Fax machines use TCP, which does resend dropped packets. This variance in Qualiy of Service sometimes cases strange activity such as both lines (sending and receiving) dropping connections, faxes taking a long time to transmit (due to constant resending loops), etc. It does work... kind of. I would just not assume that faxes made it to their destination until it gets confirmed.
Dec 31, 2010 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I recently purchase comcast internet and cable. I have a motorola surfboard SB5101U cable modem and when I try 2 connect my xbox to xboxlive, it says that my network doesn't have a sufficient MTU setting....
You actually should call comcast and tell them about the issue, They have a backdoor into your modem that they can troubleshoot it for you. The issue with their modems is they are usually locked with some weird password they use.
Usually with a modem or router you can dial an internal page but there system like Time Warner is set to their needs so that they can keep that back-door open.
Comcast phone number is 1-800-266-2278 or 1-800-Comcast same numbers thats just the way they word it on their site.
Oct 21, 2010 | Arris SURFboard® SB5101 Cable Modem
Is the average life span of the motorola cabble modem 5120 7 years?
I just spoke to comcast and they suggested three years isn't unusual for this modem to start having issues.
Jun 17, 2010 | Arris SURFboard SB5120 Modem
Moved router to connect directly to the Comcast modem that also provides VOIP. Comcast activated modem and internet works when computer is connected directly to Comcast modem. Router does not connect to...
Your ISP should have given you the following information...
Static IP, Internet IP Address, Subnet Mask, Gateway, Static DNS 1-3.
With that information at hand, follow tis link to the router user manual and go to Page 11 of the manual to go through the step by step process of setting the router up for an internet connection.
http://downloads.linksysbycisco.com/downloads/WRT54GX2v2_ug,1.pdf
Nov 26, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
I have comcast and i purchased the surfboard so that i could play use the internet for my xbox in my room. There is another modem on rent from comcast a touchstone telephony modem which provides internet...
u need a router to share internet connection, not 2 modems, from the way your explaining it im going to assume you just bought the modem went home and plugged it up, Well.. thats not going to work , your modem needs to be registered with the network your trying to access(comcast)
I’m happy to help further over the phone at https://www.6ya.com/expert/leon_509b29b7b5b43b5e
Jul 13, 2009 | Arris SURFboard SB5120 Modem
Internet connection issue. Is it setup or internet service
The problem would be comcast. Your connections are setup correctly. The modems do not control the internet traffic flow, they are made to produce maximum flow.
If more people use the internet, the less flow it will have.
Check all internet options settings, and make sure EVERTHING is set to automatic
Jun 06, 2009 | Arris SURFboard SB5120 Modem
Wireless router stops internet connection to modem during install
are you sure your hooking the comcast modem in the right place?
Feb 08, 2009 | Arris SURFboard SB5120 Modem
Computers & Internet Logo
307 people viewed this question
Ekse
Marvin
Marvin
