Question about Lexmark X Office Equipment & Supplies
We have a new x642 printer which is telling us there is an error code 920.07. It previously was telling us we had an error 922.04. We had to replace the power supply on this thing even though it was brand new. This thing is a piece junk considering the price paid for this thing. How do we correct it?
Posted by gc1978 on
5 Related Answers
Anonymous
  • 18 Answers
SOURCE: Canon Pixma IP600D - error code 6502
What is the brand name and model of your printer? Make sure that your ink cartridges are precisely the correct cartridges for the brand and model that you are using. From what I have experienced ... if you try to use a used ink cartridge you will recieve an error.
Please refer to the following link http://www.coldreset.com/modules.php?name=News&file=article&sid=60
Terry
Posted on May 26, 2008
David Shaub
  • 2976 Answers
SOURCE: my kodak easyshare 5100 is a piece of junk, THINK TWICE BEFORE YOU SPEND YOUR MONEY ON THIS.
I too thought it was junk, until I learned to use it correctly. I was not using the program right. I have since printed about 800 photos and another 1000 or so pages of text, without a problem. Keep paper in BOTH storage areas, don't refill the ink cartridges. They use PIGMENT based ink. Other inkjet printers use DYE based ink. Make sure the printer defaults are set to what you need. If you're going to print something other than default, after you hit print, pick the proper setting for what you want from the first window that pops up. I've had about 15 printers over the years and the 5100 AIO is by far the best printer I've ever had.
Posted on Jan 01, 2009
leroyal
Leroy Elliott
  • 2120 Answers
SOURCE: supply expired
You can't. Cartridges have a date bomb built in, they may be expired.
Posted on Jan 20, 2009
Anonymous
Sometimes the Canon printers which use PG-5BK/CL-8 colour cartridges with chips will give error massages like 6502 or other types of error message to do with the cartridges, which has the orange light flashing and the printer will not work. Follow this procedure which quite often resets the printer and allows it to resume printing.
When error is indicated, turn power switch off so green light is extinguished.
First hold down resume button and then hold down power button so both are held down at same time
When green light comes on, continue holding down power button and let resume button go, then press resume button twice. Then let power button go.
Then press resume button four times, power button should be released before doing this.
Wait until printer settles down, if power is off, turn on. If power will not come on, remove power cord from back of printer, then wait 15 seconds before plugging back in again and turn power on. This normally solves the error problem - if not go through same procedure again.
Incidentally, you may find that if the chips had previously been disabled, the low ink warnings are showing again and they will have to be disabled once more. This would indicate that the above procedure clears the firmware memory of the disabling of the chips, this may be useful if you need some warranty work done on your
printer after the chips had been disabled.
Posted on Jun 10, 2009
Caleb Judd
  • 157 Answers
SOURCE: Lexmark Z2490 - printer cartridge not supported
Take them out and put them back in, make sure there is no sticker on them that should be removed before installation.
What are the cartridge model numbers?
Posted on Jun 18, 2009
Xerox C2424 error code 19,003.48 and 07,010.43
There is a problem eith your printhead.Try to get new printheads
Have you tried lubricating the slider rails, you should do this before replacing anything.
goodluck,
Please don't forget to rate me as fixya..
Jan 28, 2008 | Office Equipment & Supplies
Canon printer S200SPx error code 5600
The user manual does not talk about specific error codes. From other forum I belong to, it looks like it may be a bad printhead. If that is it, Canon says to call support. I suspect the cost of a new printhead would be more than the printer is worth.
Jul 31, 2009 | Canon S200X Ink-Jet InkJet Printer
Code error 5800 has come up and printer will no longer work
Error 5B00 tells you that the ink absorber is full and needs changing. Canon makes this shut down printing so that ink doesn't leak on your furniture and blame them. You can change the absorbers but you need access to diagnostic functions to reset the count and clear the error code.
Jun 23, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Print Cartridge Error
Have had much experience with HP AIO models and would try to double check the contacts on the cartridge carriage.. sometimes a q-tip swap dipped in alcohol gently over the contacts will fix this - also note the dates on the ink cartridges (even the new ones) If the dates are previous to the date showing on the machine, this will give this error, but can be worked around by clearing the memory with a factory or full (hard) reset that sets everything back to zero dates. THis usually involves holding down certain button combos while plugging the machine in... Try a search for reset codes on HP site or google with model number and "reset code" to find the proper button combo.
Jan 08, 2009 | HP PSC 1410v All-in-One Printer
Getting a 290.01 error on lexmark x644e
This is fairly common issue. Usually this is just a problem with the pick rollers position on the enganging tab.
So open top cover where the feed rollers are. Follow the shaft of the pick rollers to the front of printer. You should see a CLAER tab somewhere. It is supposed to sit on TOP of the WHITE engaging tab but more than likely is under it. Take something small & flat like a key or small flat head screw driver. PUSH the WHITE tab down which will aloow the CLEAR tab of the pick rollers to move up into the correct position. Close the cover. You should NOT have to power cycle the unit.
The cause for this is usually someone either over stacking paper or leaving a staple on the paper.
Dec 02, 2008 | Lexmark Office Equipment & Supplies
Epson service call error message 00010014 Call customer Service and Support Call 1 8O5*465*751O Toll Free 24x7
The 00010014 error code indicates that the Ink System Pressure Sensor reports low pressure.
This error usually is caused by an Ink Cartridge that leaks pressure.
thanks for rating
Jan 09, 2008 | Epson Stylus Pro 9800 InkJet Printer
Installation Error
Hi, What is the printer that you are trying to install?
Aug 09, 2006 | HP OfficeJet 4215 All-In-One InkJet...
Open Questions:
71 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
CheckitRight
CheckitRight
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
