1988 Lincoln to town car. ignition switch has dead spots effecting turn signals and power windows as well as engine shut off cost of repairs or difficulty of do it yourself
If the only issue with the radio is that it will not turn off and then drain your battery, I would locate the power wire to it and put an on/off switch on it to manually do the deed . Repair not cost effective. Make sure it is the radio responsible for the drain. Use an ammeter to check power usage with ignition off and radio connected and disconnected to just make sure.
Check your starter relay, it is mounted to the fenderwell near the battery. On the relay there is a terminal labeled "S" take that wire loose and check for power when the key is turned to start, if there is power you need a relay, if there is none you have and ignition switch or safety neutral switch problem.
I think you might try Autozone or Oreillys for a free scan. Make sure you have an Alternator that is putting out the full amount. There are several stages built into the alternator and it can run with one or two missing.
There are relays but usually you either have power or you don't. You need to have the amount of power draw measured with the engine running and the lights off or on. Then you need to measure the power draw with the engine off, ignition off to see if anything is running that should not be.
A rear window defroster can silently pull great amounts of power. A bad ignition switch can keep things powered up when the key is off and out of the ignition.
If your main brake lights are not working and the third light in the back window is working
it is the turn signal switch on the column cost about 150 to have replaced
