Sounds like a wheel barring but it started when i would drive down. whenever i turn the wheel to the right, there will be a vibration in the front. Now, it happens all the time when i drive but its a constant humming noise and when i turn to the right, it makes the humming and the vibrating humming noise together
Rob, assuming this is a 4X4? Sounds like a bearing. They can vibrate, snap, clunk, all kinds of terrible noises or vibrations. Axle u joints will also do this. Is it all wheel drive?
tie rod ends dry? this kind of thing is easily found if one person moves the wheel and the other listens and/or feels the different front end components. loud squeaks are generally accompanied by vibration which is hard to miss if you get down close to it.
if you feel the pulsation in brake pedal when stopping. its a warped brake rotor thats causing it. for bad cv joint symtoms--- Unusual noises when making turns. As you are driving on the road and you make a turn at the corner, if you start hearing unusual sounds coming from under the car then this is one of the symptoms of a bad CV joint. These noises will sound like something is clicking beneath the car every time you turn the steering wheel. Evidence of a damaged boot. Steering wheel feels heavier. The steering wheel will start to feel tighter and heavier and you can hardly make simple turns to the left or right. In severe cases you might even feel heavy vibrations like you are driving down a rocky road.
High speed steering wheel vibrations and wobbling are almost always due to an unbalanced tire. Start there, cheap, and then move onto more expensive front end part repairs. If you have those silly mag type big wheels which collect and hold gunks of ice in them, then this is what you can expect.
when turning left vehicle distributes weight to right front wheel bearing causing load. since u describe a noise in right front while driving straight i would suspect failed right front wheel bearing. see if your noise changes/goes away while turning right that should tell u 4 sure
Jack up the front end and put stands under it and block rear wheels. Look at axle boots and see if they are cracked. Try turning wheel back and forth sharply and see if you can hear any clicking. Problem could be outer axle joints. If the boots are cracked or you hear a clicking noise you will have to replace the axle. The axle and boot come as a complete unit. Please let me know what you find out.
hello have u rotated the tires front to rear then drive and see if u still have the noise and vibration if drive yes while driving slowely turn the steering wheel left to right just a small amount if the noise changes its probably a front wheel bearing if that doesn.t help drive the truck till you get the vibration then let up on the gas pedal does the noise go away if so you might have a bad u_joint but do the tires first how many miles???????
