SOURCE: al1917w lcd monitor resolution problem
Get a new video card, you dont need the best video card to support 1440*900. It is affordable and the best solution.
SOURCE: widescreen resolution...
Every video card has it's max resolution. To see what your max is for the d530, if your running a version of XP. Open Control Panel. Open Display. This will open Display Properties. Click the Settings Tab. Listed there is screen resolution, sliding the marker all the way to More will give you your Max resolution. I have a high end video adapter & my max resolution only goes to 11280x1024. You may have to contact HP/Compaq. The link listed contains updated drivers for the d530 but there is a bunch listed because each d530's have different internal devices.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=316715&prodTypeId=12454&prodSeriesId=316713&swLang=13&taskId=135&swEnvOID=1093#11360
You can chat with HP/Compaq at this link:
http://h20000.www2.hp.com/bizsupport/TechSupport/ContactHP.jsp?lang=en&cc=us&prodTypeId=12454&prodSeriesId=316713
This is your best shot! Good luck.
Please vote...
map
SOURCE: LCD projector does not display video
Re: Intel 810/Beryl no video overlay
With VLC you do:
1. Go to Settings/Preferences/Video/Output modules/XVideo
2. Check the Advanced options below.
3. X11 display name change to 0, XVideo adaptor number to 0.
Thanks
SOURCE: VIA Chrome9 HC IGP vs Samsung 940BW Plus (1440x900)
Assuming you're using the latest drivers from here , the next step would be to ask MSI for a bios upgrade that supports the higher resolution.
SOURCE: Hannspree 19" Widescreen resolution available
I have the same problem. i downloaded a generic driver that allows 1600 X 900 resolution. this is better..things are taller rather than wider (with the 1280X1024 resolution). i dont understand why there isnt a 1440X900 driver available for XP systems.
