Question about Ademco CIA Modem
I want to buy 1 ademco cia modem - Ademco CIA Modem
Posted by moropoki on
russvan
    New Friend:
  • 74 Answers
Google"Ademco CIA Modem"and you will find several sources.
AlarmProfessor.net
Posted on Aug 23, 2010
1 Related Answer
JaxPlanet
Jax Planet
  • 923 Answers
SOURCE: I can't get windows XP to see/detect my Ademco cia
According to my web search you need Ademco Compass Software V 1.5.8.0. Part # CMP1580ADCD
See: http://www.alarmsuperstore.com/ademco/ciamodem/ciamodem.htm
I hope this helps
Posted on Apr 24, 2010
How to reset ademco after chanhing battery
You have to run a system test. enter your code then press 5. If that does not work try entering your code then press 5 then 0. it all depends on system type. let system test run for about 2-5 minutes it sould reset. Ademco 6150 6150pl3 6150pl2 these identify your keypad model not system type.check your control box to identify your panel. Sould be like Ademco vista 10, 20, 20p
Feb 18, 2011 | Ademco 1 Ademco 6150 6150pl3 6150pl2...
Need to change alarm code on ademco alarm ststem
We need more information. The answer is different for different models and Ademco has dozens of models. Tell us the model of your control panel, usually on the inside of the panel cabinet door) and we can help you.
Oct 04, 2010 | Ademco 1 Wave 2 Alarm Indoor Siren Vista...
Alarm will not arm & displaying 05 in control window.
What alarn panel/system are you using?
Aug 31, 2010 | Ademco CIA Modem
I can't get windows XP to see/detect my Ademco cia modem. Is there a driver needed
I hope this helps
Apr 24, 2010 | Ademco CIA Modem
I move into a house that had a alam system by att
I assume that you do not have an alarm code to turn the system off.Contact the Professor and he can walk you through a defaulting of the alarmpanel.
AlarmProfessor.net
Apr 21, 2010 | Ademco CIA Modem
Alarm went off. When I shut it off I now can't
Enter master code and press off a second time to reset alarm memory.
Aug 25, 2009 | Ademco CIA Modem
Ademco 4160-12 was installed in my house in 1987.While exterior painting, the external siren wire is cut. Please help me find new siren and procedure to alarm system. This has at present only local ( siren...
any 12 volt siren will work. you my have to replace the fuse. 12volt sirens are available at radioshack, frys electronics and all over the web,
mj
Aug 06, 2009 | Ademco CIA Modem
Ademco CIA Modem Logo
243 people viewed this question
Top Ademco Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you an Ademco Computer and Internet Expert? Answer questions, earn points and help others
