Question about Siemens Food Processors
I purchased siemens food processor one year back at chennai, India. However i am not able to use the same effectively since i am not aware/(forgot) of all the features ( it is having around 14 accessories). Could not understand the user manual. Hence kindly provide me any video describing how to use the siemens food processor along with accessories( i.e user manual in video )so that it will easily understood by myself and by my mother too.
    Top Expert:
  • Siemens Master
  • 30,785 Answers
A model number may help you get an answer
Posted on Jun 25, 2017
5 Suggested Answers
6ya staff
SOURCE:
lolita
Rona Heredia
  • 385 Answers
SOURCE: User Manual
Here is the direct link to your food processor user guide: http://useandcares.hamiltonbeach.com/files/840150200.pdf Enjoy Lolita
Posted on May 18, 2007
Jaime Hernandez
  • 2337 Answers
SOURCE: Sunbeam Food Processor/Le Chef 14-11, 14-1A
Check this website: //http://www.householdappliance.com/food_processor_parts.html
Posted on Jan 21, 2008
Anonymous
SOURCE: service cetersin chennai,india
Actually Braun does not have any service centres in India, they would be planning shortly to have one here in India, till then all Braun Users would be at the mercy of Fly By Night Mixie Service Technicians...!
Posted on Jun 19, 2008
Anonymous
My mom gave me her Le Chef that had several cracks in the handel and also the place where the handel attaches to the bowel with a screw was broken. I Used Loctite super glue for the crackes in the handel and a loctite epoxy putty that can be molded into the shape needed to fix the place where the screw attaches the handel to the bowel. After the putty set I sanded it to refine its shape and matched the screw hole in the bowel with the handel then drilled a small polit hole in the handel. I slipped the handel into the slot in the bowl and attached it with the screw and now I have a good as new Le Chef.
Posted on Jan 27, 2009
Sir, I have Molinex Food Peo of model 370.It has started giving noise when switched on. More over its safety switch is also broken. need to replace safety switch. I feel the carbon brushes have been worn...
Sir, I have Moulinex Food Processor of model Master Chef 580 .It has Problem with the Moulinex DG6 6.34 Cups Food Processor Sir, I have Molinex Food Processor Master Chef model 580.It has started giving noise when switched on. More over it's safety switch is broken. need to replace safety switch.Also Motor's Rotor's winding is burnt.Needs rotors replacement. Please intimate service center &spare part supplying agency in India. I am in Vadodara (Gujarat) India
Jan 19, 2011 | Moulinex DG6 Food Processor
Can you give service centre in chennai
Can you give service centers in Bangalore?
Aug 25, 2010 | Braun K 750 CombiMax Food Processor
BRAUN food processor Service Center
no there is not but u can caall the company and have it
Jun 29, 2009 | Braun K 750 CombiMax Food Processor
I am at chennai How can i get aspare part for setting right the machine
From the Braun Website, refer to
Sai Services
Office No 01, Ground Fl. Nav Yojana Housing Co-Op. Society
400034 Mumbai
Phone Country Code: +91
Phone: 22-23813830 / 3649 / 3378
Otherwise, refer to http://www.braun.com/global/contact/servicepartners/asiaaustralia.html and select India as the country, you can select the closest city.
Apr 13, 2009 | Braun K 750 CombiMax Food Processor
The Blender attachment will not turn, just grinds and smokes.
The motor shaft that spins the teeth that are on the base of the blender may be frozen up for some reason. If you purchased the duet within the last 3 years and have a receipt, call Cuisinart to get it repaired in warranty - even if you don't have a receipt, your serial number may still save you. If you purchased it more than 3 years ago, let me know.
Mar 12, 2009 | Cuisinart BFP-703 SmartPower Duet Food...
Food proccessor jar damaged
yes ask the shopkeeper to give u used one
Jan 12, 2009 | Siemens MK-22201 Food Processor
Service cetersin chennai,india
Jan 18, 2008 | Braun K 750 CombiMax Food Processor
It just stopped working
Remove the work bowl from the base of the food processor, and separate the bowl, lid, and pusher sleeve.
Plug the base into the wall outlet, turn the food processor ON, and then use a pen to press in the dark grey or black button on top of the base of the food processor - if you hear some kind of noise, then your motor is still good.
Put the work bowl on first, with the handle facing the front of the food processor.
Put the lid on, with the hollow feed tube facing the back of the processor.
Put the pusher sleeve in the lid, with the sliding lock switch facing the front of the processor.
Your processor should now turn on.
If your food processor still does not turn on, call Cuisinart and see if you are eligible for an in-warranty repair - it has a 3-year warranty.
-Tha Mp3 Doctor (also loves Cuisinart)
Oct 29, 2007 | Cuisinart DLC-10S Pro Classic Food...
Food Processors Logo
371 people viewed this question
Top Siemens Food Processors Experts
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a Siemens Food Processor Expert? Answer questions, earn points and help others
