My mobile samsung jet wifi connection has problem .my laptop connecting properly, so means no network problem i have. mobile showing authentication failed, no response from AP or DNS failed etc etc. . please send me the complete browser setting , like proxy address, encryption type,protocol, network key etc
if its about authentication than your putting the password wrong. also i think your limited on the devices you can connect to it . if im not mistaken its like 4
Is the wifi enabled, can you see any wifi networks? If not, make sure wifi is enabled, if there is button on laptop to disable/enable wifi connections, swich wifi on.
Check from control panel -> network (network and sharing center in Vista/Win7) -> change adapter settings. If wireless lan adapter disabled (grayed out).
I think your mobile has been very old or you use to connect your mobile to wifi a lot before,there could be some problem with your mobile software so once reinstall your mobile operating software
check your wifi settings by turning on your wifi, instead of selecting wpa or wpe, select infrastructure and select none for password. try also dragging your wifi home network to your phone wifi icon. and check.
Most likely means that the security protocol that the college system uses to authenticate users is not supported in your phone. You can talk to the IT departement to see if they'll recognize your device as an authorized machine, but they'll most likely not because of security concerns.
Yeah, they confirmed that they have some problem on some wifi authentication especially when your AP is configured to WPA-PSK (TKIP or AES).
you can only connect wifi with open, shared, WEP 64 and 128bit authentication and WPA/WPA2.
Samsung still dont have any solution to this big issue. Been a lot lately to customer service in plaza sing, talked to the manager a lot with this problem, still NO SOLUTION. You can't even have a full refund, no change model.
You will be asked for a password only if you are connecting to a password protected WiFi network.You can set a password for your Home WiFi modem and after that you have to enter the password whenever you try to connect.
