Question about Philips PM3S Remote Control
I have a Sanyo DP19649 hdtv and have lost the remote for it. I have tried setting a Phillips Universal remote using the codes listed for Sanyo and using the code search function also with no success. Could it be that the remote I have does not contain the correct codes for this tv. Where can I get them or a remote that works with this TV?
Posted by fox4049 on
5 Related Answers
Anonymous
  • 59 Answers
SOURCE: I need codes for a phillips tv and a phillips universal remote?
Hi michaeljlent,
There are a number of codes for your remote that correspond to Phillips TV models. They are:
002 009 109 202 209 210 310 402 408 508 510 807 901 914 917
For your reference, here's a web address where all the codes for your remote are listed (along with programming instructions):
http://www.universal-remote.net/philipsmagnavox.html
I hope this helps - please let me know if I can be of any further assistance.
Posted on Dec 12, 2008
Anonymous
SOURCE: I need the 4 digit codes for Philips Universal
need code for rm 4912 remote control
Posted on Apr 17, 2009
the q guy
Tony Walker
  • 393 Answers
SOURCE: need tv codes for phillips universal remote ph601s
I found that these websites should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
if this helps please give a fixya rating as thats how we get paid.
Posted on Jun 21, 2009
Anonymous
  • 74 Answers
SOURCE: I need Philips CL035A codes list for toshiba tv
I believe this is your remote. it's listed as pm435s
http://www.p4c.philips.com/files/u/us2-pm435s/us2-pm435s_dfu_eng.pdf
these are the codes for toshiba 0517, 0419, 0512, 0613, 0719, 0112, 0506, 0111, 0618, 0627, 0437, 0041, 0094, 0802, 0111, 0313, 0715
Posted on Sep 17, 2009
Anonymous
SOURCE: I have a phillips CL034 universal remote need code for sharp tv
this should work:
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
Posted on Oct 19, 2009
Changing channels without remote sanyo dp19649
You should have a remote control to select all its functions. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
Jul 23, 2016 | Sanyo Televison & Video
I have purchased a new remote for my sanyo tv. the lights on the remote buttons will not light up.
J. if you know the lights on remote are to light up and they do not, it is defective, return for replacement or refund. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Sanyo DP19649 Owner Manual Remote Control Operation
How to Program Universal Remote Welcome to Remote Central Universal Remote Control Reviews More
Apr 12, 2016 | Sanyo DP19647 DP19648 DP19649 DP26640...
Codes for newstar lcd -led -hdtv universal tv remote (NTR-WU6E) i lost the manual..pls i need answer i cant use the remote in our sanyo 32" led tv..
2908,2986.2990. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://electro-medical.blogspot.com/
Nov 12, 2014 | Televison & Video
Remote codes for a DP32640 tv with a GE universal remote
i think you can get a replacement remote from www.tvassist.co.uk. if you can't find the remote you need listed then contact them. These are not universal remote though they are specifically built for your model no.
Sep 08, 2013 | Sanyo DP19649 LCD TV
I lost my remote control while moving. Where can I get a new one. will auniversal type program as well as the original.
Any will work, however finding the codes can sometimes be tricky
There are online sites that list the codes, as well as booklets that list the codes for THAT universal remote.
You can play it safe and get a logitech harmony series and I can promise it will function just as well if not better
Please rate if this has helped you!
Mar 03, 2011 | Sanyo DP19649 LCD TV
Need to program a GE Universal remote for Sanyo HDTV DP19649. Sanyo codes listed by GE don't work. Thanks!
http://www.remotecodelist.com/remotes/old-index.html
in this page you need read step by step for solved you problem...
bye
Mar 07, 2010 | Sanyo DP19649 LCD TV
Need a remote code my new sanyo tv to go with att-uverse cable sanyo #dp19649
I went through all the Sanyo TV codes and then started entering in groups of 10. The U-verse offered 1103 i did 1100 to 1110 and it worked with 1107. Unfortunately at&T said you have to check the manufacturer which doesn't list universal codes. I was lucky on the Sanyo 18.5" LCD from Walmart using 1107!
Aug 31, 2009 | Sanyo DP19647 19 in. LCD TV
Sanyo tv codes
The codes listed by Sanyo for my TV won't work in my star Choice remote.
I tried 017 021 039 056 057 058 and 140 as listed by Sanyo.
Any ideas?
Dec 18, 2007 | GE JASRM24912 Remote Control
Code for sanyo tv phillips universal remote cl034
the code is 0506 Ihave the same remote and tv
Dec 15, 2007 | Televison & Video
Philips PM3S Remote Control Logo
198 people viewed this question
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
