Hello and Welcome to FixYa!
Actually the leaking water is from the evaporator coil unit.... Under normal conditions,Self-defrost refrigerators usually dispose the water generated during the defrost cycle through a tube or channel that directs the water a pan (Known as Drip pan), commonly below the refrigerator unit....
The channel or tube is clogged and the water is leaking to the refrigerator unit, so you need to clear that contamination....Once the blockage is removed, the generated water will move through that channel/tube directly to the drip pan and there will no water on the top shelf in the refrigerator compartment. Another cause may be the refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says “energy saver” or something like that, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the water disappears the problem is solved.
Best of Luck,
Please do Rate the solution, if you feel that this helps you,
Concerned.
SOURCE: refrigerator leaking water out
being in the uk, i don't know this appliance specifically so take this as guidence. there are two places where water can come from. at the rear of the fridge there should be a gully at the bottom of the evaporator wall - the part that frosts up. in the middle of this gully is a drain and this is likely blocked. push something flexible down it and check blockage is cleared by pouring a small amount of water in the gully and see it flows freely away. good idea to occasionly pour a small amount of dilute bleach down it now and again to keep it sweet. the other place for water to come from is if some of the contents of the fridge are touching the back wall. when it defrosts the water tends to divert onto the shelves
