My foxsat-hdr box will not switch on or off from the remote or the button on the front of the box. It is stuck in BOOT mode and can only be switched off at the back of the box. help
Posted by robinsquicke on
Anonymous
    New Friend:
    Problem Solver:
  • 5 Answers
Do a power cycle. Unplug the box from the ac outlet and then wait a couple of minutes before plugging back in. If this doesnt work , contact your provider to have them reset over the phone or to ship out a new box
Posted on Aug 18, 2010
Humax foxsat hdr code to be used on sony rm-ed012
Hello
Four digit universal remote codes for Sony TV with Humax Foxsat remote are:
0037, 1505, 0036, 1925, 1825, 1751, 1685,
1651,1625, 1551, 1317, 1010, 0834, 0810,
0353, 0074,0011
Three digit codes are:
006, 301, 005, 446, 412, 393, 375,
360, 325, 255, 203, 185, 174, 058,
003
OK.
Jun 18, 2011 | Televison & Video
My Humax Foxsat is just out of guarantee & the remote has suddenly stopped working. We have changed the remote batteries & it is lighting up but doesn't interact with the foxsat box. The box works...
If you still have the owners manual i would recommend looking for the section on how to program the remote to the receiver. If the remote works with other accessories that would probably be it if not you can find universal remotes pretty cheap.
May 04, 2011 | Humax Televison & Video
Can i download a manual/user guide for my foxsat-hdr recorder?
Yes. Try this manual;
www.humaxfoxsathdr.co.uk/.../Humax-Foxsat-HDR-User-Manual.pdf
Feb 21, 2011 | Humax Televison & Video
Vehicle is stuck in valet mode. Steering column is locked. Vehicle is a 2006 Jaguar XJ8L. Cannot open the glove box to get the owner's manual.The battery is fine.
Open the boot lid and drivers door, and switch on the ignition. Rock the valet switch, in the centre console, 5 times. The system will chirp to indicate it has entered learning mode.
On models with seat/mirror/steering wheel memory functions, the first remote will be linked to memory 1, second to memory 2 etc.
Press the larger, lock, button of the remote. The system will chirp to confirm it has got the signal. If it doesn't receive any signals for 15 seconds, it will chirp twice and exit learn mode.
To programme further remotes, rock the valet switch once. The system will chirp twice for remote number two, three times for number three etc, then press the lock button of the remote as above.
When finish, wait 15 seconds for the system to time out and chirp twice, turn off the ignition, close the doors and boot lid and the job is done!
Mar 07, 2010 | 2006 Jaguar XJ8
I have a Humax foxsat-Hdr and wish to route my DVD player (toshiba 80-220E) through it to save long scart runs, the manual is opaque on this point - any ideas, Nick Yates
Just connect the scart from the dvd to the dvd scart on the humax. Viewing the dvd player output is attained by pressing the source button on the humax remote.
Jan 13, 2010 | Televison & Video
Humax Foxsat HDR sudden Remote Control failure..
Make sure you have pressed the "PVR" button at the top. If you have accidentally pressed on on the others TV, DVD or AUDIO then they will light up when you press another button signifying that the remote is trying to send a signal to them rather than the PVR...which is where you want it to go.
Nov 10, 2009 | Televison & Video
Setting humax foxsat hdr remote to control panasonic tx32lxd60 tv
Had the same problem with my panasonic - it would appear that none of the codes will actually turn the TV off because they need a longer signal to turn off. I eventually found that code 0650 works for mine - input the code as instructed in the manual and then selected OK - holding down the standby button on the humax controller then turns the TV off. Try all the codes and see which gives most control functions. Hope this helps.
Jan 01, 2009 | RCA 3-Device Universal Remote with...
Televison & Video Logo
94 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
