Question about Olympus Camedia C-720 Ultra Zoom Digital Camera
Does The Memory Card Need TO Be In During Charging
  • 4,102 Answers
Hi, it wont make any difference as long as you remember to put the memory card back in after it is charged, most people only take it out if they need to put the card into a reader to transfer the pictures to a computer other than that you can leave it in all the time.
it will charge with it in and without it in the camera, so which ever you prefer, you wont do any damage to the card if its in the camera whilst charging
let me know if you need further assistance ok
Posted on Aug 18, 2010
    New Friend:
    Problem Solver:
  • 11 Answers
No the memory card is completely seperate to the battery pack, in or out, it will still charge.
I have nokia 3500c with memory card in it playing music and so on it just for some time it stop playing and tells me memory card not formated
omo copy all songs from memory card to pc or phone and format the memory card and then copy again to memory card, this is a minor error ocurred during copying and deleting the data on memory card.
Jun 28, 2012 | Cell Phones
After charging W350i not recognising SIM says, 'Insert SIM Card'. But the same SIM card is operative in other mobile. How can retrieve Phone contacts? Please help.
make sure if sim reader is not pin damaged or water damaged? if problem persist i think you can connect your device without simcard and copy all data to your pc, then give some repairer to check maybe need to flash (if flash you will lose your data).
or try to put your mobile without battery 2 days and then switch on to see may be this problem solves.with S.E. this problem a normal.
Jun 21, 2012 | Sony Ericsson W350i Cell Phone
How to remove the memory card from a c3 nokia phone
Hi kat_brynne
After reading the solution to your problem could you please rate if my answer was helpful thanks...
1 Open the cover of the memory card
slot.
2 Insert the card into the memory card
slot with the contact surface facing
up, and press until it locks into place.
3 Close the cover of the memory card
slot.
Remove the microSD card
Important: Do not remove the memory
card during an operation when the card is
being accessed. Doing so may damage the
memory card and the device, and corrupt
data stored on the card.
You can remove or replace the memory
card during phone operation without
switching the device off, but you need to
ensure that no application is currently
accessing the memory card.
Cheers nikki
Jan 22, 2011 | Nokia C3 Cell Phone
After charging my LG Vu Plus there was a message on screen that said, "Memory card is ejected. Default storage location is changed from memory card to device." I had not messed with my microSDHC...
The memory card has most likely corrupted and no longer will work. you can try to reformat it in your computer, but more than likely youll need a new card
Apr 07, 2017 | LG Cell Phones
I have a 2 gb sandisk memory card which stays inside my phone all the time. I was charging my phone over night and woke up and it was still charging. My phone didn't recognise the memory card inside it...
This is all you can do! If you have a laptop with a port to use ur memory card, try inserting in that and see what happens. Still there is no response means you should go to a service shop. Request them to take a backup if u have any sensitive data in it before formatting it. Btw the problem would not have arised because of overnight charging. The data might have got corrupted
Aug 01, 2010 | SanDisk Memory Media
I want to k550i formatting number
Below are some helpful tips for what to do if you can't turn your phone on. Be sure to try each one to determine the nature of the problem.
  • First, make sure your battery is fully charged. If the battery is drained out, it may take up to 30 minutes of charging before the battery-charging icon appears on the screen.
  • Press the On/off key for a minimum of 10 seconds to turn the phone on.
  • If your phone has a memory card, remove the memory card and try to power the phone on. If the phone turns on, you might need a new memory card.
Jun 10, 2010 | Sony Ericsson K550i Cellular Phone
Long beep sound during POST
The long beep during post means there is a conflict in the start up procedure in the Bios. This can be anything from bad ram to hardware failure. If it starts up and the time is wrong the beep could be your internal bios battery is dead.(just a small watch battery )
Jan 28, 2010 | Office Equipment & Supplies
LG Vu C920 automatically switches off while charging
i know this sucks but you may need a new battary.
Apr 13, 2009 | LG Vu CU920 Cellular Phone
Screen problem
most of all this problems do come for the fact that the storage medium is infected with virus.
did you scan the memory before and after it was inserted and taken out of the laptop.
try also taking out the memory card and put the phone off and on again..................if nothing happens change the memory card and see what happens..........................on the other hand have your phone flashed to see if the problem would be solved.
Now during charging put the phone on and enter this (your phone would be formated and you would lose everthing on the phone)
*#7870#
entering *7370# would only reset the phone but nothing would be lost.
good luck
May 15, 2008 | Nokia 6288 Cellular Phone
Problem with lg flat panel
Check the settings on the Setup Menu to see if you can diable the memeory card checking function. It also sounds like you need to have a memory card inserted for user definable settings to be saved. Why not try a memory card in it?
Dec 28, 2006 | LG 26LX1D 26 in. LCD HDTV
Olympus Camedia C-720 Ultra Zoom Digital Camera Logo
105 people viewed this question
Top Olympus Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you an Olympus Camera Expert? Answer questions, earn points and help others
