Question about Car Audio & Video
I changed my battery with a new one so now i had to code the radio. i entered a wrong code and by mistake i pressed the AS button. I tried to enter the code again but the display showed safe and number 7 Normally it shows 10 and safe. What shall i do to be able to code the radio correctly. Thanks
Posted by anthony zammit on
kenw392
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Car Audio & ... Master
  • 2,226 Answers
Try leaving the radio turned on for an hour or two.
Posted on Aug 18, 2010
I NEED A KEY CODE FOR THE BUILT IN RADIO IN A FORD FIGO 1.4 AMBIENTE 2012 MODEL
Try this, found it on another answer board.
Press and hold the Auto button. While holding the Auto button, push and hold the Track Up button. The “_ _ _ _” will disappear after about 5 sec. Enter KCAR using the remote control from a higher end CD Receiver or any Excelon CD Receiver. Enter "KCAR” with the remote controller as described below. “K”: Press TRACK UP key (>>|) after pressing 5 key twice. “C”: Press TRACK UP key (>>|) after pressing 2 key once. “A”: Press TRACK UP key (>>|) after pressing 2 key three times. “R”: Press TRACK UP key (>>|) after pressing 7 key twice. * If you commit a mistake in the code entry, the unit enters the code request mode again. Press the Track Advance button on the remote to enter the override code. The unit will enter the All Off or Standby mode if done properly. Video Unlock: Use a remote from a higher end CD Receiver or any Excelon CD Receiver. Some Video remotes will work, switch on remote must be set to AUD. Press 55222277 on the remote. There will be NO visual verification when entering the override code. Head units with a Up / Down Volume control buttons: Press and hold the Volume Up button. While holding the Volume Up button, push and hold the Disp button. The “_ _ _ _” will disappear after about 5 sec. Enter KCAR using the remote control from a higher end CD Receiver or any Excelon CD Receiver. Enter "KCAR” with the remote controller as described below. “K”: Press TRACK UP key (>>|) after pressing 5 key twice. “C”: Press TRACK UP key (>>|) after pressing 2 key once. “A”: Press TRACK UP key (>>|) after pressing 2 key three times. “R”: Press TRACK UP key (>>|) after pressing 7 key twice. * If you commit a mistake in the code entry, the unit enters the code request mode again. Press the Track Advance button on the remote to enter the override code. The unit will enter the All Off or Standby mode if done properly.
Read more: How can I get the key code for ford figo radio systems? - Radio system key code ford figo :: Ask Me Fast at http://www.askmefast.com/How_can_I_get_the_key_code_for_ford_figo_radio_systems-qna4609185.html#q2909005
Dec 09, 2015 | Ford Cars & Trucks
I have a 2000 saturn ls and my code is 8870. Does anyone know what it is to unlock my radio
Do you want the instructions of how to enter your code?
  1. Turn the ignition ON.
  2. Press the power button on the radio. The display will show "- - - -".
  3. Enter the four digit code by using the and rocker buttons. The numbers will start at 0 0 0 0 and will increase on the display each time the corresponding side of the rocker button is pushed.
    1. Press the down arrow side of rocker button to change left digit.
    2. Press the up arrow side of rocker button to change second to left digit.
    3. Press the down arrow side of rocker button to change third digit.
    4. Press the up arrow side of rocker button to change last digit.
  1. Push the AM/FM button once the four-digit code has been entered correctly.
  2. If the proper code has been entered, the radio will return to the armed mode and normal operation shall return. If the wrong code is entered, the display will momentarily show an error message and then return to display "- - - -" indicating that another try at the correct code can be attempted.
Oct 19, 2014 | Cars & Trucks
Entering radio codes for a 1998 passet
If you don't have MODE and SCAN buttons ( I didn't ) you can try as above but with TP and TA - they worked for me.
Feb 22, 2010 | 1998 Volkswagen Passat
How do I enter the radio code to unlock the radio
I'm assuming that you have the code to enter. The following indicates the procedure. If you don't have the code, leave a comment and I will indicate the process for getting it.
If your car’s battery is disconnected or goes dead, or the radio fuse is removed, the audio system will disable itself. If this happens, you will see ‘‘Code’’ in the frequency display the next time you turn on the system. Use the Preset buttons to enter the five-digit code. If it is entered correctly, the radio will start playing.
If you make a mistake entering the code, do not start over or try to correct your mistake. Complete the five-digit sequence, then enter the correct code. You have ten tries to enter the correct code. If you are unsuccessful in ten attempts, you must then leave the system on for one hour before trying again.
Hope this helps you.
Nov 27, 2009 | 2002 Honda Accord
Ive got a factory radio reading of i have code how do i reset to put in code
When you turn on the radio, it will say "codE" on the display. You have the 4-digit code number for your radio, to enter the first digit, press the "1" button on the radio the number of times until the first digit matches. For example, if your code is "2156" then, press radio preset button 1 two 2 times, then press radio preset button 2 one time, then radio preset button 3 five 5 times and finally preset button 4 six times.
THEN if the display is correct (should show 2156 in this example), press TAPE button. You should hear a beep and the radio should be working. If you make a mistake and enter a wrong code, the display will show "Err". You have 3 tries to get this correct or the radio may be toast. These are the steps for the stock radio in my 1995 GSX and they've worked for me each time I've lost battery power. Good luck!
Apr 09, 2009 | 1995 Mitsubishi Eclipse
CHANGED BATTERY IN 93 SAAB 900 NOW MY RADIO WON'T WORK
Someone put the wrong security code in the radio. Hold the DNR button down and the code will clear. Be sure you have the correct code to enter after clearing the current one.
Jan 24, 2009 | Clarion ABD340MP AM/FM CD/MP3/cassette...
Need to input my radio code on 2005 Honda Civic
ok your radio displays ERR , OK 3 options let it sit for an hour turned on , to reture to CODE display , or pull the radio fuse out for a minute and put it back in , returning to the CODE display , or disconnect the battery for a minute , returning to the CODE display . you got the ERR display because the code was wrong or not entered correctly , make your choice of getting the radio back to the CODE display by 1 of those 3 choices , while the radio displays CODE , use the preset buttons , if the first number of your code is 4 , then press the #1 preset button 4 time , when the first number has been input , put the 2nd number in by pressing the #2 prest button , if 2nd number of code is 8 , press the # 2 preset button 8 times till the # 8 is displayed , and so on . you see where this is giong ? when you have entered all the numbers correctly you will have you radio back . when you say you have the radio code , good luck ! were rooting for ya .
J5
Jan 19, 2009 | 2005 Honda Civic
Radio code
If you have tried a few times before NOT entering the right code or making error when entering code. This radio will lock you out, here is what you do disconnect battery cable for 60 seconds (positive cable) or disconnect radio fuse. Then re-enter code make sure that you are pressing firmly on number and make sure that you enter correctly.(POWER ON RADIO SHOULD BE IN ON POSITION WHEN DOING THIS) If this doesn't work then you will need to go to HOnda and fora fee they will be able to get code. Good Luck and thanks for using FIX YA.
Jan 10, 2009 | 2004 Honda Accord
I enter the code for a6 and phono comes up on display
try entering it again, also try changing from different modes on the radio.
Dec 02, 2008 | 2001 Audi A6
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
