Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
My folder's turned into 1 KB Shortcuts on my 500 GB WD Hard Drive, it seems like memory in my HD is used, but when i click in to open folder it says that file cannot find :(
Posted by nigina_m on
Anonymous
    New Friend:
My files was 2kb
Posted on Aug 02, 2012
Anonymous
    New Friend:
  • 34 Answers
Well, it's obviously your external WD drive infected with virus which stop you from accessing the data by turning them into shortcuts (such as 1KB or 2KB). This blog article how to fix folder become shortcuts should help you out. Follow the step by step please. Note: do not attempt to format the drive before you try.
Posted on Jun 04, 2011
2 Related Answers
Anonymous
SOURCE: My folder's turned into 1 KB Shortcuts on my 500 GB WD Hard Drive
I believe this is a trojan. I have the same problem. I found by going into Properties-shortcut tab- you have to rename the shortcut to the correct shortcut. You should notice some wierd file name like "keuiku.scr." Simply rename it to the original name and it works for me.
Posted on Aug 01, 2010
NNNNNanette00
  • 30 Answers
It sounds like your hard drive is virus infected. Have you tried to scan this drive with your computer antivirus tool?
You should always be careful when you decide to separate/delete some suspicious files.
Or you prefer to firstly use a hard drive data recovery freeware that could deeply scan your computer and recover back all your needed data back:
http://www.freeware-fix.blogspot.com/2013/02/hard-drive-recovery.html
Remember to back up everything important on different drives next time.
Posted on Aug 28, 2013
2answers
4 gb usb creating shortcuts folders
I think you are referring,that there are folders and shortcuts which are not created by you and its generating automatically?
if this so, Its an action of a virus. - Run full system scan using a up-to-date virus scanner.
3answers
I have a 500 gig portable hard drive and all of my files have turned to 1 kilo byte shortcuts how can i retrieve them back
This is going to be hard to hear, but those are just shortcuts, not the files themselves. Which simply means that if the shortcut no longer has a valid file to point to, those files are not and never actually were on the drive. I see this alot where I work as people do not understand how to actually copy their files for backups. Clicking and dragging often produces this result. In most cases if the original files are gone, then there is no way to retrieve them.
4answers
Is this the Problem???
Don't format your Flash Drive.
Your data is still there.
Use Shortcut Virus Remover.
  • 100% free
  • Setup file to download 1.1 Mb
  • Installed file 2 Kb
It will recover your all data.
DOWNLOAD !!!
http://shortcutvirusremover.blogspot.com
2answers
32helpful
9answers
1helpful
2answers
Can not open files on other computers from WD external drive
Actually, I have a similar problem.
If you get an error message that says something like "You do not have permission to access this file" or "Access Denied" then these steps should be a temporary fix:
  1. Go to the menu bar & select Tools>Folder Options
  2. Select the view Tab, & look for "Use Simple File Sharing". Uncheck this (Disable it).
  3. Right-click on your external drive icon & click "Properties". Choose the "Security" tab & click on "Advanced".
  4. Click the "Owner" tab, then select the user from the list below (whatever user you're logged in as). Then check "Replace Owner on subcontainer and objects", & click OK>OK.
You are done! But if you don't need the whole HD, you can do steps 3-4 on whichever folder/file you want to access to reduce time taken.
Remember, this is temporary, meaning if you take the HD to another computer then you will have to repeat the steps to regain access of your HD. Any permanent solution?
Cannot sync from Western Digital Passport 320gb HD
try and format using your vista or xp tools,right click on the hard drive go to format and format it as a ntfs drive.
I got a 500 gb. x hd. need reformat.
Get your system in safe mode. Just plug in the HDD and hold on the left shift ( dont autorun it).Now open windows explorer.
Rigth click on the HDD and click format..Choose to full format.
1helpful
2answers
Wd problems
Change the drive letters, worked for me. I have 2 WD My Books, I made one R: and one S: worked fine after that. On vista go to Control Panel -> Classic View -> Admin Tools -> Computer Management -> Disk Management -> Right click on WD drive and change letter. For some reason G, F, E, ect seem to run into some problems
Top Western Digital Computers & Internet Experts
Marvin
Marvin
Mike
Steve
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
