Possible that there is line break to the panel board.So firsst you must check this out before we can go further.
If no power check the wire for break.
If power is coming in to the board , check fuse, if fuse blows it ispower issue,failure in the power circuit.
If power is Ok , then the processor controller is defective.
Might have to replace the board then.check cost and proceed.
Hope this helps Good day
Hi
The 'LE' error message indicates the control
board has detected that the motor is either not turning, or has locked up for
some reason. Monitoring the motor is the job of the hall effect sensor board
which constantly determines the direction and speed of the motor and feeds that
information back to the control board. If there is a problem between what the
motor should be doing and what the hall effect sensor says the motor is doing,
the 'LE' will be displayed and the cycle will be stopped.
This error can sometimes present because of a miscommunication between the
control panel and the wash motor. In this instance, the washer simply needs to
be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged,
press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE
code is cleared.
Please get back to us if you have further
query or else please accept the solution.
Thanks for contacting fixya.com
