Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
When we switch on our Sony Trinitron, the red light keeps flashing, audio comes on but it takes a very long time 3 min approx for the picture to show up. Also the clarity and colour of the picture has worsened. What is the problem and is it worth repairing? Thank you.
ABRsvcs
  • 4,234 Answers
This could be a sign of hte picture tube failing. If you are comfortable accessing the set with teh back removed, try a screen adjustment as follows:
1) locate the flyback transformer (part with large red wire coming out the top)
2) There should be 2 adjuistments on that part labeled screen and focus.
3) turn the screen control clockwise just a bit
If the set comes on more quickly, than the tube is starting to fail. The adjustment above is a temporary "fix" that will get you time to locate a replacement only. Further adjustment will cause the picture to be washed out and may show retrace lines as well.
Hope this helps,
Dan
Posted on Aug 18, 2010
Testimonial: "Thanks. It worked. It comes on faster."
Anonymous
    Problem Solver:
  • 14 Answers
Adjust the screen pot at the flyback just a little bit higher and it will have display.
Posted on Aug 30, 2010
Anonymous
    New Friend:
  • 3 Answers
Try this .. Check for 200V if present on the PCB attached at CRT tube. My TV has this problem also. Just search for 220K resistor located near Hout drive for flyback. Inspect if ok.
[email protected]
Posted on Aug 22, 2010
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
My Sony Trinitron 36'' model#: kv32v26 is taking a long time to show picture when turned on. The sound comes on and the red light blinks for about 3-5 min. before the picture turns on. And when i switch to...
Hi Matt.
I`ve been repairing sony tv`s for a long time now and i can tell you that what you described is sure signs of a weak picture tube.
And the price of a new picture tube makes it prohibitive to replace it. You could open the set and adjust the screen control on the high voltage transformer but it won`t last long. If you decide to do that , look for a transformer with a long and thick red wire that connects to the back of the picture tube , That is the flyback transformer and there will be two controls on it, you want to adjust the bottom control that is the screen control(the upper one is the focus).
Turn your tv on and slowly turn the screen control up until the picture shows up at a reasonable brightness level, if yout turn it to high or you may get retrace lines in the picture.
That may strech the life of your set for a couple of months .
Hope this will help. Merry Christmas
Dec 16, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony Trinitron KV-28LS36U no sound or picture, the standby light flashing green and red but if i switch it on a little bit of sound comes and then switches off. how can i repair?
The unit is shutting itself down because a problem was detected internally. When this happens, the standby light should blink a repeated pattern. Please count the number of blinks and post the number here. That will indicate the circuit in which the problem occurred.
Thanks,
Dan
May 19, 2009 | Sony Televison & Video
Sony Trinitron KV-24FS100 red light flashes 4 times
your tv had a problem.if you have a knowledge in electronics, check or replace the horizontal transistor beside the plyback. it is a black square parts with 3 pins.
Jul 03, 2008 | Sony FD Trinitron WEGA KV-24FS100 24" TV
Sony FD Trinitron WEGA KV-36HS500 blinking red light 6 times
smack it on top a couple of times, it works for me :)
if ya cant duct it, smack it...
seriously...
Jun 29, 2008 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony Trinitron Blinking Chanel 3
I have a 36 Trinitron, the sound and picture went but the red light just keeps blinking, any ideas? Please ....
Feb 26, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Please Help
Is the red light flashing a code ? exaple 4 blinks pause 4 blinks ?
Apr 07, 2007 | Sony KV-27FV16 TV
No sound or picture now
The set may have shorted the horizontal out put transistor since it kept coming on sometimes. This could be cause by the driver transformer arcing causing a "spike" in voltage going to you horizoltal out put transistor. Stargazer
Mar 31, 2007 | Sony KV-27FV16 TV
No picture just clicking sound
with your model number manny have a defective flyback part number is 1-453-310-11
regards,
daniel.
TV solution
You may have a bad solder joint on the horizontal driver transformer or somewhere else in the set. I found this problem with this transformer several times. Stargazer
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
348 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
