Maytag Neptune MAH5500B Front Load Washer Logo
Posted on Aug 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Washer won't start. Display shows "od"? - Maytag Neptune MAH5500B Front Load Washer
Anonymous
Level 3:
  • Master 1,998 Answers
  • Posted on Aug 18, 2010
Anonymous
Master
Level 3:
Answers
1998
Questions
0
Helped
620397
Points
5972
Od is an open door error if the door is closed then you would have to replace the door switch or the wiring that goes to the door switch first try to open and close the door and make sure it seats properly in the small hasp type holder if the error code still persists then check the wiring to the switch and if the wiring looks like everything is connected well then you would have to order a new door switch i hope this helps in your appliance situation and please remember to rank this solution if you have any more questions please message me back. Have a great day
rickead1
2answers
Od code on my Maytag Front load Neptune Washer...Hi, could anyone please share more info on DIY fixes, I have tried everything under the Service mode and eventually did a Board Output Test also..
17 The door / cover switch has not been opened since the last two last revolutions. The door did not open after two complete washing cycles. The door switch has not been opened since the last two revolutions. Displays "od". If the door is open, the error disappears. Check the door lock probably bad.
Also you might need to reset it.
Press power/cancel then start/pause
  1. Press power/cancel first.
  2. Next, pick a fresh cycle to run.
  3. Press start/pause to reset your Maytag washer.
  4. Run a test load afterward to confirm that the washer has reset.
Best to you.
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
When you push start button nothing happens
Washer will not start , od code is showing on the panel
You have lost signaling from the Left Hand Lid lock.
The OD code is sent out from the Console main control board when a lid open is not sensed via the signaling from the Left Hand Lid lock for three completed wash cycles.
Google this sticky for help with your issue ""Neptune TL Washer FAV6800AWW"" start at the 5th post down. You will find a link to the service manual and help on troubleshooting your issue.
"od" message
The OD and OP error codes are trouble shot the same way. See if this link will help.
display shows OP but unable to clear
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference
If you need additional help let me know.........Rich
2helpful
Will not start up and show code 0d
Hello kc59mail ,
For the FAV6800A the od alarm means the Control Board has not seen a lid open condition for three complete wash cycles. I suspect the left lid lock.
I think you have a problem with the magnetic reed relay in the left lid lock. If you could try this? I want to make sure you signal an “OP” alarm to the display. Can you select Spin Only cycle with the lid open press start. Do you signal the “OP” alarm lid open to the display? If it does close the lid and the “OP” alarm should clear does it? I’m checking that the lid magnet is in place and the signaling connections are working thru the left lid lock back to the control board.
Let us know what you fin and we will go from there. You could try powering down the machine by removing the 120VAC power cord from you wall receptacle. That may give you three more wash cycles before the od alarm is triggered again.
2answers
My machine has a code and is full of water
can you provide the full model # and also the full error message?
Maytag Neptune washer
It stands for 'open door'. The control board didn't see that you've opened the door since the last cycle and won't start another cycle until it see's that. Probably a bad switch in the door latch assembly. If you can verify a bad switch, it's best to replace the whole latch assembly. It also may be a shorted wire, trace the wiring back from the latch to the board and check for any signs of damage. It's possible, but very unlikely, that the control board is bad. If everything else checks out it's the board.
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
