Panasonic DMR-E55 DVD Recorder Logo
Posted on Aug 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We are trying to unlock the region code on our DVD player Panasonic no DMR-ES15 to enable us to play multizone imported DVD's . Can you help. Thanks
Kristine
Level 2:
Sergeant:
  • Panasonic Expert 294 Answers
  • Posted on May 07, 2020
Kristine
Panasonic Expert
Level 2:
Sergeant:
Answers
294
Questions
0
Helped
171785
Points
904
Some Blu Ray player manufacturers leave a back door for removing the region code, while others don't allow users to heck their players at all.
Fortunately, there is a place where you can find exactly how to hack you are Blu-Ray player to make it region free, and that is the VideoHelp forum.
You can check more solutions here:
3 ways on how to make your Blu-ray player region free
Muntejaya Ginting
Level 3:
  • Master 10,422 Answers
  • Posted on Feb 27, 2011
Muntejaya Ginting
Master
Level 3:
Answers
10422
Questions
Helped
2469895
Points
19564
2answers
Hi, I recently purchased a Panasonic DVD S48 dvd player. I was assuming when I bought it that it was a multiregion product. This seems not to be the case as it will not play region 1 dvd's that I...
hi Pjkgbr.
this is all i could find out, now if you do try this do so at your own risk.
This hack requires the S48 remote plus a universal remote configured for the S48 with a separate 'Pause' button (or another Panasonic DVD remote with a separate 'Pause' button may work).
I used a cheap universal remote.
1. Select DVD device on remote.
2. Hold magic button until the DVD button blinks twice.
3. Enter device code 0490 (DVD button blinks twice)
Neither the 'Play/Pause' nor 'Frame' buttons on the S48 remote work for this hack.
1. Power on.
2. Open tray.
3. Using the S48 remote press Audio, 1, 9, 8, 2, Subtitle
4. Using the other remote (URC 7562) press Pause.
5. Using the S48 remote press 0.
The DVD front panel should now show the text "on".
The DVD should now be region-free. Region code hack posted by spook65, December 12 2012:
DVD-S48EG-K (Region 2)
This is the process for unlocking, the Panasonic DVD-S48 for
multi-zone.
Please note, you will need a universal remote control which
has a PAUSE button in order to unlock this player.
1. Turn the power ON
2. Open the disc tray
3. Using the remotes, press AUDIO 1 9 8 2 SUBTITLE PAUSE 0
4. Switch the player to STANDBY and then switch ON again.
The display should read ON after you enter PAUSE 0.
If this doesn't happen, switch the player off and start the
sequence again.
The remote supplied with Panasonic player has a PLAY/PAUSE
button rather than a separate PAUSE button. If you use the
PLAY/PAUSE button, the tray will close and the unlock
sequence will be aborted.
To get round this, you need a universal remote set-up to use
with the DVD player. After pressing SUBTITLE on the
Panasonic remote, quickly press the PAUSE button on the
universal remote, then press 0 on the Panasonic remote to
complete to unlock code entry.
or this one.
What is the process for Multizoning a DVD-S38 / DVD-S48 / DVD-S58 / DVD-S68 / DVD-S500 / DVD-S700 DVD Player? Providing your DVD Player is one of the below models, you can multizone the unit yourself using the remote supplied with the product and another Panasonic product remote thas a Pause button on it
Applicable Models:
Multizoning Process:
1. Power on the unit and open the disc tray
2. Using the remote that came with the player, press the following buttons in sequence
3. AUDIO 1 9 8 2
4. SUBTITLE
5. Using the other Panasonic Remote (not the one that came with the player), press the PAUSE button
6. On the remote that came with the DVD player, press the 0 (zero) button
7. If you have followed the above process correctly, the word ON should be shown on the front panel display of the player*1
*1 Please note: The models DVD-S500 and DVD-S700 do not have a front panel display,
so the only way of confirming that the multizoning process has been done correctly, is to
try playing a DVD disc from another region code other than region 4
1helpful
2answers
Panasonic dmr-eh57 multi-region unlock code
Region free hacks On this page you can find everything about region hacking your player. As this site was also the place where the generic Panasonic DVD player region hacks originated from, it also covers almost any other Panasonic DVD player.
http://www.dcevolution.net/panasonic/index.php?option=com_content&task=view&id=32&Itemid=54
--- I do not accept any responsibility whatsoever on what you do to your box or any other action you take - I am just here to inform ---
3answers
2helpful
Cannot play europen DVDs
Panasonic and JVC are harder models to find Region free codes for but you may want to try here or here
How do I tell if my unit (Panasonic DMR-ES30V) is multizone?
This unit will play either Region 1 or Region "ALL" discs.
-Tha Mp3 Doctor
Panasonic dmr es15 dvd recorder
My Panasonic Recorder DMR-ES10, will not play discs sent to me from the U/K,
using a L.G dr275 recorder, onto a DVD+R disc, how can i overcome this problem. regards Tom Escott.
Panasonic DMRES15 DVD audio problem
Hi, i have a panasonic dvd recorder DMR-ES15, just wondering can that be unlocked to play region 1 dvd's?
3answers
DMR-ES15
Hi, you can't put a code for multizones or multiregions in all DVD players PANASONIC, to fix this problem you need a special remote only available in the officials Panasonic service centers, Sorry.
6helpful
4answers
All region un lock code for PANASONIC DMR EZ47V
I believe you must remove any disks in the unit & then on the remote controller, press 7 7 0 (the 0 is to make it region free)
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
