Question about Car Audio & Video
My sub wont play music but it will pop when i cut the truck on and the amp lights up
    Sniper:
  • 57 Answers
It's blown or the amp is. that pop you are hearing is the speaker clipping, meaning its getting power but no sound which means the amp or sub is blown.
Posted on Aug 18, 2010
Anonymous
SOURCE:
I have an ma audio hk2000d. A couple years ago I hooked it up to a set of subs an it played just fine underpowered then it popped a fuse on the amp. Now every time I Start playing music the fuse pops. I...
Have you tried different speakers? If a speaker has a short, it will draw too much current from the amp and pop the fuse. Also, does the amp pop a fuse on idle, or just under load. What is the gain set for?
Nov 04, 2013 | Car Audio & Video
My jl 500.1 amp dosent play anything.
you have your sub wired incorrectly. your amp shouldn't get hot unless you're settings are too high or your'e sending too small of an ohm load to the amp. this would cause it to heat up and will fry your amp.
May 30, 2010 | Jl Audio 500/1 Car Audio Amplifier
Static when playing music and speakers pop
try to clean the volume control with contact cleaners
May 05, 2010 | RCA RT2760 System
08 nissan frontier problems
No you need a new battery or alt. or both running a stereo will kill both faster. and could carosion faster too.
Jun 29, 2009 | 2008 Nissan Frontier
Protect light flashing on and off, sub cuts in and out
there is a wire crossed somewhere in the system or the sub is damaged how old is the amp
Dec 01, 2008 | PPI DCX-600.4 Car Audio Amplifier
Kicker 750.1 Amp wont play music
it is probably the rca inputs on the amp may have fried. was your cd decked turned up loudly before the power went out? did any wires accidently touch each other? If had worked fine and then suddenly stopped, than either a wire came loose or the inputs fried. try using different cables and I also suggest disconnecting power for 24 hours and then reconnect. If the green light is on then it is getting power and the problem is in the rca cables or the inputs
Jun 03, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
What could be wrong???????
The only thing left is the wiring, and or connectors from what you are describing.
You can try another amp and another set of speakers on the same wiring to see if they work. If not, the only thing you have left is the wiring and connectors (if connectors are used).
This suggestion is valid providing that substitution equipment is not defective.
Jerry G.
May 01, 2008 | Kenwood KAC-9152D Car Audio Amplifier
My amp turns on then the music cuts in and out
check your main ground, if possible try to read voltage across making sure 12-14v present with load and some signal.
Aug 08, 2007 | Verge VGA285 Car Audio Amplifier
Car Audio & Video Logo
74 people viewed this question
Top Car Audio & Video Experts
Marvin
Marvin
Mark Skinner
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
