SOURCE: SYLAVANIA green light blinks a few times and goes back to red
you have a transfomer on the inverter board failing you need to call a tech to have the transfomer replaced funai has a few hundred
SOURCE: tv comes on, green light flashes several times,
common problem with that model is the backlight inverter, 1 or more of the six transformers may be bad.also check for bad capacitors.the tedious way to check is unplug each and plug in each one at a time but unplug the power from the tv each time you check one or you will get a nice jolt. the one that doesnt light the lamp is bad.or take each transformer off and check the primary and secondary coils if you find one open coil. the transformers cost between $8 and $20 each.it has a substitute part.
SOURCE: MY TV IS ABOUT 3YRS. OLD,WHEN I TURN IT ON THE
This is caused by a poor or faulty power supply inside the TV.
you do got a few options repair yourself or have a expert do it.
what most likely happens was one of the capacitors on the power supply became defective, this happens over time. you might want to investigate purchasing a new power board for this unit.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
