Question about LG WM-2277HW Front Load Washer
We have the LG HE frontloading washer. Is there any easy solution to the mildew smell which builds up? I understnd this is common to many front load washers?
Posted by ttemple535 on
D. Floyd Kolb
  • LG Master
  • 43,501 Answers
Here is a tip that I wrote about the mold/mildew problems in front loaders...
Stop Washing Machine Smell, Mold, and Mildew
http://www.fixya.com/support/r3993813-stop_washing_machine_smell_mold_mildew
heatman101
Posted on Aug 17, 2010
Mildew smell from LG washer after use
There is a cleaner that needs to be run through the machine at least monthly. VERY common issue.
Apr 11, 2011 | LG WM2050C Front Load Washer
MY newerfront load lg machine smells like mildew leaving clothes
Front load washers are very efficient but can create odors not common in top load machines. I would suggest running a cleaner such as Affresh or Smelly washer through the machine, there are instructions on the containers but basically you run a load without clothes on the hottest settings. This will help eliminate the mildew that gets caught between the tub and basket. A treatment once a month will do wonders!
You can purchase these at Target, Lowes or grocery stores near the laundry soaps.
Apr 19, 2010 | LG WM2487H Front Load Washer
I have a mildew smell within the washer and have
Leave the door open all the time and it will dry out and the mold and smell will subside.
Mar 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Odor problems with whirlpool front load washer
Is the smell of mildew?
Run the washer on empty with beach and soap.
This is a common problem when the front door is left closed after use.
When the washer is not in use leave the front door cracked open. This will help in preventing mold & mildew.
Dec 12, 2009 | Whirlpool GHW9100L Front Load Washer
Lg washer/ frontloader
Take a hand towel soaked in vinegar, then run it around the rubber seal around the front of the door, making sure you get all the way under. Then run a load of whites with javex or vinegar. Always leave the door ajar after you are done washing, or that mildew smell will re-appear.
Nov 13, 2009 | Washing Machines
Strange smelling towels - HE Frontloader
Try running the washer with detergent and a box of baking soda--no clothes--and HOT water. Do you have very hard water in your area?
Jul 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Mildew smell
Are you useing HE detergent? If not this is your problem! The reason why you need to use HE detergent is because it is made specifically for front load washers. The regular soap is made to be deluted in 20 gallons of water your washer only fills up with about 7. so what it does is it leaves a layor of residue SINKY SINKY. Especially when you leave the door shut all the time. It's like a Bathroom if you do not ventilate it properly it will Sink eventualy. So also please leave the door cracked open.
So to getr ride of the smell Sears sells a product called Afresh or Washer Magic I prefer the Afresh you get 3 tablets and it works great atr removing odors out of your washer. Also if you are on a Well wateer it is safe to use. Or you could use good old bleach with no clothes till the smell goes away
Jan 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore washer smells/mildew on rubber
The smell problem is actually because of the softener....its nassssty stuff it coats the interior of the washer and forms a grease like residue. I would use Washer Magic (available at all appliance parts retailers) (only half the container in front loaders) and a hot wash. Also keep spraying the boot with bleach and water soluiton every few hours it will dissappear after awhile. please rate my help
Oct 04, 2007 | Kenmore 44102 Front Load Washer
LG WM-2277HW Front Load Washer Logo
630 people viewed this question
Top LG Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
