Question about Samsung LN52B610 52 in LCD TV
SAMSUNG LN52B610 TV TURNED OFF BY ITSELF. CANT TURN TV ON. NO RED LIGHT ON TV FOR POWER. OUTLET WAS CHECKED AND HAS POWER. CORD IS IN GOOD CONDITION. PLUGS FIR SNUG IN OUTLET AND BACK OF TV
  • Humberto Arreguin Feb 08, 2012
    main board HDMI port burned on the TV and TV won't power up I think the problem came from the receiver slash entertainment center output HDMI going to TV the chipis burned on the receiver, the tv is LN52B610. can I fix the TV by replacing the main board on the TV.
  • 160 Answers
Hello.
If you have multimeter available you can actually check if voltage present at the end of your power cord first.
If it's OK than you have to remove back cover from your TV and locate power supply board. It's very easy - it should be next to the power cord receptacle. First look for capacitors that have bulged tops instead of flat ones. If you locate any - replace them and check if it's going to take care of problem.
Right next to receptacle connection is fuse located and you have to check if it's open. Replace it if needed. If new fuse got blown right away - you have short in power supply board. If fuse is OK - connect power cord and using multimeter try to figure out if 5V is supplied from Power supply board to the main board (the one that have all inputs attached to it). If 5V is present but power LED in front of the TV is still dead - you could have problem with main board.
Best regards.
Russ.
Posted on Aug 17, 2010
6ya staff
SOURCE:
Panasonic TV TH-L37S25A no power no red light, when plugged in and turned on at wall.
I'm guessing your power board went out and will need replacing. If you have the model number correct your going to have a hard time finding that board, I looked and couldn't find one anywhere, couldn't find that model listed
Feb 09, 2018 | Panasonic Televison & Video
40" Samsung LN40B610 1080p LCD HDTV suddenly turned off; will not turn back on (NO red light or clicking sound)
Here is a place that I buy parts from: It is pretty inexpensive. Note though that with a big screen television, the service people come to your home and then you get charged for a service trip fee. So if you want to save money on this, take the set to them! You should know that those sets have to be transported verticle or the screen will break. http://www.shopjimmy.com/catalogsearch/result/?q=LN40B610+
Feb 17, 2014 | Samsung LN-S4051D 40 in. LCD Television
Samsung la32s81b
Probably the power supply is failing or has failed.
Oct 24, 2017 | Televison & Video
No power to tv
have you checked the power to the outlet?
Sep 07, 2012 | Emerson Lc320em1f TV
Is the red light suppose to stay on when you turn off the tv with the remote?
Yes it is supposed to stay on. This is the standby light. The television still draws power as do many electronic devices when not turned on and when in standby. If you do not want the red light to stay on you will have to unplug the television.
May 09, 2011 | Samsung LN32A330 32 in. LCD TV
Samsung LCD won't turn on.
sometimes the power cord comes out behind tv , the power outlet is bad in the wall,
Jan 21, 2009 | Samsung LE40R74BDX 40 in. LCD Television
AKAI 32" LCD HDTV WILL NOT TURN ON
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to [email protected]
Nov 27, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Lcd tv
dos the porew light stay red or turn blue or not at all?
May 31, 2008 | Polaroid FLM-323B Television
Samsung LN52B610 52 in LCD TV Logo
482 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
